[NY] 113 heads with upper end
completely redone 113 heads. bigger valves, new springs, retainers, etc, etc. 3 angle cut. bead blasted. still in the plastic bags from the machine shop. The heads were built for ~400 HP.
TPI plenum, runners, intake, fuel rail. all hot tanked, and cleaned up by a well known Long Island machine shop. the windage trays from the bottom of the intake are there.
$850 takes all. the heads are worth that alone.
Re: 113 heads with upper end
What springs are in them (seat/open rate, max lift, what is the max lift the heads are setup for)? Any porting done?
Will you split up the heads and intake?
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
In that case, I'm interested in a price on the heads.
evilstuie
Jan 9, 2020 08:29 PM
theshackle
Mar 5, 2017 06:37 PM
ambainb
Apr 25, 2016 09:21 PM
