Subscribe
Sep 26, 2011 | 10:39 AM
Reply 0
Sep 26, 2011 | 02:59 PM
Re: Spohn Coil Over Pro-touring Front setup
Does that include the struts?
Reply 0
Sep 26, 2011 | 07:34 PM
Quote: Does that include the struts?
No. You use whatever struts you have. i installed these on the KYB struts that have been on my car for years.
Reply 0
Sep 26, 2011 | 09:16 PM
What's the difference between prodrags and protours? Comes with strut mount too correct? How much without mounts
Pics to j.mwatkins@yahoo.com
Reply 0
Sep 26, 2011 | 11:00 PM
Spring rate and ride height adjust ability is the difference.
Reply 0
Sep 27, 2011 | 08:42 AM
You need the mounts for the coilover setup to work.
Reply 0
Sep 27, 2011 | 03:37 PM
What would be the advantage of going with system?
Reply 0
Sep 27, 2011 | 08:19 PM
Spohn Performance's Pro Touring adjustable front coil over kit for the 1982-1992 GM F-Body Camaro & Firebird sets a new, higher standard of performance and quality. When we designed our coil over system, we had two goals in mind. One was to provide the performance capabilities needed for the toughest race tracks, the second was to provide the strength and durability required for the demands of a daily driven vehicle. We're proud to say that we have accomplished both. If you are looking for the best front coil over suspension system for the third generation F-Body, you just found it.
Once thought of as a race only item, coil-over suspensions are now considered the hot set-up for any highly tuned street car. The combination of incredible handling with great ride quality is what one expects from a world class car. With a Spohn "Pro-Tour" coil-over conversion kit you will have the no-compromise handling you demand without paying a penalty in comfort. Allows lowering of vehicle over 2" yet still maintains ample strut travel!
Mount Specifications:
•CNC laser cut 1/4" steel base plate
•4" DOM steel tubing
•CNC laser cut 3/16" steel top hat
•CNC machined bearing mount tube - TIG welded
•Chrome moly spherical bearing with a Teflon® self lubricating race
•Underside of strut mount includes the coil over spring mount
•Powder coated gloss black for a brilliant and durable finish
Coil Over System Specifications:
•CNC laser cut 1/4" steel reinforcement plate fits in the entire recessed area of the underside of the strut tower
•CNC laser cut 3/16" strut mount retainer with Grade 10.9 mounting bolts and stainless steel nuts
•CNC machined 6061 T-6 aluminum threaded coil over strut sleeves (clear hard anodized). Custom designed and built by Spohn Performance. Specifically designed for use on the thirdgen front strut. Proper wall thickness is maintained to support the load they are carrying.
•CNC machined 6061 T-6 tempered aluminum adjustable bottom spring seat (clear hard anodized) allows for ride height adjustment. Custom designed and built by Spohn Performance for use on our threaded strut sleeves. Includes nylon tipped (no-mar) set screws. Allows lowering of vehicle over 2" yet still maintains ample strut travel!
•2.5" Torrington thrust washers and bearings on the bottom AND the top of the spring, provides for no spring bind and allows for easy on car ride height adjustments (spanner wrench included).
•2.5" i.d. x 12" long coil over springs, available in a variety of spring rates
Reply 0
Oct 3, 2011 | 03:54 PM
Would like to sell. or trade for a Weight jack setup.
Reply 0
Oct 5, 2011 | 05:26 AM
How much for the coilover kit without the strut mounts or springs?
Reply 0
Oct 5, 2011 | 08:12 AM
Quote: How much for the coilover kit without the strut mounts or springs?
Sorry selling as a whole. Not sure how you would use it without the strut mounts. But if you want PM me an offer for the whole thing.
Reply 0
Oct 5, 2011 | 05:18 PM
Quote: Sorry selling as a whole. Not sure how you would use it without the strut mounts. But if you want PM me an offer for the whole thing.
I have umi strut mounts
Reply 0
Oct 5, 2011 | 05:41 PM
... and now I know, I'll let you know shortly. Shipped to Canada? Whitby, Ontario.
Reply 0
Oct 6, 2011 | 06:04 AM
Quote: I have umi strut mounts
Color? Could work out a trade.
Reply 0
Quote: ... and now I know, I'll let you know shortly. Shipped to Canada? Whitby, Ontario.
I'll give you a quote today.
Reply 0
Oct 9, 2011 | 08:54 PM
tothetop
Reply 0
Oct 13, 2011 | 08:54 AM
Come and get it.
Reply 0
Oct 13, 2011 | 02:36 PM
would need to weld this in right? i mean its not a direct fit right
Reply 0
Oct 13, 2011 | 04:26 PM
Quote: would need to weld this in right? i mean its not a direct fit right
It is a direct fit. No welding required.
Reply 0
Oct 13, 2011 | 04:38 PM
Might be interested. Ill shoot you a PM after work
Reply 0
Oct 15, 2011 | 09:18 AM
Still have this?
Reply 0
Oct 16, 2011 | 07:00 PM
Quote: Still have this?
Yes i do.
Reply 0
Oct 18, 2011 | 04:29 PM
Will trade for a weight jack setup.
Reply 0
Oct 19, 2011 | 09:24 AM
tothetop
Reply 0
Oct 21, 2011 | 10:26 AM
Are you negotiable on the price? Its not far from buying them brand new with free shipping that most of the vendors have available.
Reply 0
Oct 21, 2011 | 03:58 PM
I'd let it go for $500 shipped.
Reply 0
Oct 24, 2011 | 07:52 AM
Pm sent
Reply 0
Nov 9, 2011 | 10:37 AM
I'll let these go with my Adj KYB struts now to for $620 shipped and PayPal Fees.
Reply 0
Dec 6, 2011 | 06:27 PM
still have them?
Reply 0
Dec 12, 2011 | 07:33 PM
Do you still have these for sale?
Reply 0
Subscribe
