[DE] Really Nice Set of Vortec Iron Heads
Old Oct 16, 2011 | 01:24 PM
KO1's Avatar
KO1
30K mile set of extra clean heads, valve job touched up, new seals, new set of GM Performance LS6 beehive springs good for .570 lift, Comp Cams Chrome Moly retainers and machined keepers, heads machined for screw in studs and guide plates, Comp Cams guide plates, ARP 7/16" studs, TFS black aluminum 1.6 ratio roller rockers. I will inlcude a set of .015" thick Felpro head gaskets and a set of head bolts. $700 for everything
Old Oct 17, 2011 | 08:34 PM
83 Crossfire TA's Avatar
Re: Really Nice Set of Vortec Iron Heads
Do they still have stock valve sizes? Are the springs good for .570" with proper clearance (I'm guessing .620" or so before coil bind)? Where in DE are you?
Old Oct 17, 2011 | 09:21 PM
KO1's Avatar
KO1
STD valves Springs will coil bind at .650 I'm in New Castle 19720
Old Oct 19, 2011 | 09:51 AM
KO1's Avatar
KO1
Vortec heads will only handle .550 lift without retainer to guide contact
Old Dec 3, 2011 | 09:15 AM
right, so like they sit, are they good for .550, .570 or? And is that a "till contact or coil bind" number or is that w proper clearance (typically .050" further till contact or coil bind)?
do you still have them?
Old Dec 3, 2011 | 03:34 PM
KO1's Avatar
KO1
SOLD
Frozer!!!
Jan 19, 2024 04:55 PM
Fast355
Dec 2, 2016 06:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
InfinityShade
Aug 22, 2015 08:00 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
