[IN] LT1 intake and heads
Old Nov 12, 2011 | 03:59 AM
85 roc it's Avatar
Car: 85 IROC
Engine: 385AFR head, Mini Ram Intake
Transmission: 6 Sp.
Selling LT1 intake converted by LT1 intake and a set of LT1 heads converted to run on gen 1 block. Coolant holes filed then heads deck. Holes already drilled and router in placed to run with a remotoe thermostat housing, housing include. Heads redone with new seals and valve job. Only ran for several minutes. Fuel rails included. Intake is 94+ so it has the fron fuel line cross over. Sold as package only.
$500.00
Old Nov 12, 2011 | 04:08 AM
85 roc it's Avatar
Car: 85 IROC
Transmission: 6 Sp.
Re: LT1 intake and heads
can email pics
Old Nov 25, 2011 | 01:30 PM
83 Crossfire TA's Avatar
how did you have the coolant plumbed (looks like you may have enlarged the factory coolant hole in the front of one of the heads in the picture, but the other side would be blocked by the alt location in the pic)?
How did it run?
Old Nov 26, 2011 | 03:28 AM
85 roc it's Avatar
Car: 85 IROC
Transmission: 6 Sp.
Yep, used a mid mount bracket for alternator. It ran good while it ran. only ran a couple of minutes to make sure new wire harnness and ECU was working correctly.
Old Nov 27, 2011 | 08:28 PM
any pics of the completed assembly? Thermostat housing included?
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
hayesaw0210
Aug 23, 2015 11:15 PM
theurge
Aug 21, 2015 12:46 PM
