[PA] Comp Pro Magnum 1.6 rocker arms
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Sold
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Re: Comp Pro Magnum 1.6 rocker arms
Sorry to interrupt your sales thread but what are you stepping up to??
Car: 89 Iroc-z
Transmission: TH400
scorpion aluminum rockers with a .150" offset intake. My new heads require offset rockers with 3/8" pushrods so these have to go. These would have worked with a smaller 5/16" rod but my setup needs to have abit thicker stuff for stability. Heavy valves/higher spring pressures/etc.
Car: 91 GTA
Engine: 377ci
I need to get my stuff measures I may be interested, I am contemplating shaft rockers also.
Car: 89 Iroc-z
Transmission: TH400
The scorpions are still stud mount like these comp's...just the intake is offset
Works good so far in my mock ups. Need adjustable guideplates too
Works good so far in my mock ups. Need adjustable guideplates too Trending Topics
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Not trying to low ball but I would have to buy studs and guide plates to use these with my 113 corvette heads.Would you consider $125
Car: 89 Iroc-z
Transmission: TH400
Not at this time. I'm not sure I can go below the 160 shipped. They are well worth that price.
Car: 87 Iroc
They are worth the price you are asking .I'm sure someone will buy them.
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Hey orr89rocz, what head are you going to and what head are you getting away from? I may get the rockers from you for the vert motor I need to finish.
Car: 89 Iroc-z
Transmission: TH400
Had AFR 195's with upgraded ARP 7/16 studs. Now have Speier V2.72 245cc heads and these require offset rockers so hence I am selling these.
What do the new heads flow?
Car: 89 Iroc-z
Transmission: TH400
~330 at .700 but they have a great velocity profile across the port
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
