Complete TPI -
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Complete TPI -
OK, let me first day that I will doing a swap to carb w/in the next month... The parts will not be shipped until I pull them off of the car and do the swap... PLEASE keep that in mind
I will have a complete TPI setup (Injectors, manifold, wiring, rails, etc...) I wont cut any wires that are vital and if i can get away w/ it, I'll leave it 100% un-cut... I DO NOT want to seperate I know someone is doing a complete swap! No work has been done on any of the intake parts
Price is $400obo for everything (+ Shipping of course)
I will do a partial trade OR a complete trade if you have the following:
-650 Carb, vac sec carb ... just LMK what you have
-Vac Adv HEI distributor... the large cap version please ..
-Roller Cam ... Need something that will be good from 1500 - 6000 (or close)
-Valve Springs good to .550 or .600
-Vortec Heads OR aluminum heads w/ the center bolt holes angled like the vortecs
Car: 1984 camaro z28
Transmission: 5 sp
Re: Complete TPI -
just curious im assuming its for a 350 set up? i have a 305 so im guessing i would need smaller injectors if it is. also will the ecm be included? again not sure how a 350 ecm would work with the 305 but i am considering swapping out my carb'd set up if i cant get it running right. got a rochester rebuilt with bigger jets etc, but guy modded it to get rid of computer stuff and im having a few issues. if i get that squared away i will have that carb and a brand new hei dist. with vac advance and a 65k coil. i believe the qjet is officially capable of 750 cfm now..though not 100% on that. it can be changed back to comp controlled im sure too if needed.
Car: 1988 Iroc-Z
Re: Complete TPI -
Yes it is a 350 setup... I'm not sure of the interchange but I wouldnt guess it would be that different.
Terrell351
Jun 13, 2021 01:13 PM
Sanjay
Aug 12, 2015 03:41 PM
