385 LT1 engine F/S
Car: 1989 camaro
385 LT1 engine F/S
here is the parts.. i have a ton of receipts proving it all as well.. i just bought a car and this was in it.. it runs and drives.. you can hear it run before i pull it out as well if u want to
-Eagle Crankshaft, 3.75" Stroke
-KB Pistons, .40" Over, Forged Aluminum
-Eagle Connecting Rods, Forged 5140
-Eagle Splayed 4 Bolt Billet Caps
-Lunati Voodoo Cam, 535@231 int./550@239 exh./110 LSA
-Accel 300+ Digital CD Ignition
-Perfect Circle Piston Rings
-Clevite 77 Bearings, Mains, Rods and Cam
-Comp Cams High Perf. Valve Springs, Locks and Retainers
-Comp Cams Pro Magnum Hyd. Roller Lifters
-Lunati Valve Springs, Locks and Retainers
-Proform 1.5 Roller Rockers
-Summit Billet Timing Gear Set
-MSD Billet Adjustable Optispark
-Moroso Oil Pan
-Moroso Oil Pan Studs
-Moroso Solid Motor Mounts
-ARP Head Studs
-Custom Machined Flywheel and Balancer
-Profesional Products Harmonic Damper
-Vortech Intake Elbow
-MSD Blaster Coil, 48,000 Volt
-Bosch +4 Tritium Plugs
-Bosch 8.5mm Wires
-Fel-Pro Engine Gasket Kit
-AIR/EGR Eliminator Kit
-CSR electric waterpump,
-Edelbrock Dual 58mm Intake Manifold,
-BBK Twin 58mm Throttle Body ,
-Accel 32 lb/hr Fuel Injectors,
i also have a set of pacesetter long tubes, full 3 inch exhaust, cant remember the brand,
any questions feel free to ask. looking to get 3100 or make me a reasonable offer. thanks!
-Moroso Oil Pan
-ARP Head Studs
-Bosch 8.5mm Wires
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Re: 385 LT1 engine F/S
Forgot to post the info on the heads included on the engine.
