[MI] 2.8 MPFI with 700r4 (51,000 miles) complete with harness, ecm and serp. setup
Old Feb 7, 2012 | 09:47 PM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
Finished my v8 swap and it's time to part with the v6. Wanted to hold onto it for numbers matching reasons, but man, this thing takes up alot of shop space! Engine ran just fine when pulled 6 months ago. Tranny still attached. Only has 51,000 original miles on setup. Has new alternator, MAF sensor, O2 sensor, plugs, wires, cap, rotor. Needs 1 relay pig tail to be re installed on harness. (cooling fan, charge relay). I needed that part for my v8 harness. Harness is complete(minus previously stated) with ecm. Needs a new good home. Have a engine crane to load in your vehical.
500 bucks and it's gone
Heck, if you want to do a v8 to v6 swap and turbo charge, i have springs, mounts, tranny cross member, radiator and v6 tach all available also. This all came out of an 89 camaro RS. My Grandmother (no lie) was the original purchaser of the car. I bought it from her a number of years back with 42,000 miles on it.
An extra 100 gets you all this with the motor...
Heck, I aslo have the drum (3:42 open) rear axle for sale also. complete. needs nothing. I swapped to a disc, posi, 3:73 axle.
60 bucks
I'm in Allegan Michigan. 45 minutes south of Grand Rapids.
Old Feb 10, 2012 | 10:03 PM
88cam23's Avatar
Re: 2.8 MPFI with 700r4 (51,000 miles) complete with harness, ecm and serp. setup
If your willing to part a few parts out let me know please.
Old Feb 11, 2012 | 12:08 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Too bad your so far. Love to have that tranny. Bump for ya.
Old Feb 21, 2012 | 09:29 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
willing to part engine?
Old Feb 21, 2012 | 09:40 PM
What are you after?
Old Feb 21, 2012 | 10:05 PM
Engine: L31 350
heads
Old Feb 21, 2012 | 11:54 PM
300 bucks for complete motor. 100 bucks for transmission. That's all the farther I want to separate.
Old Feb 26, 2012 | 04:39 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
I would be interested in the harness with ECM for the right price, and the tachometer as well, if you are willing to sell those things separate PM me please.
Old Mar 4, 2013 | 11:12 PM
dennisschreuer's Avatar
Car: 87 RS Camaro
Engine: LS6
Transmission: Tremec 6 Speed
Axle/Gears: FAB 9, Floater, 370 True Trac
IM SURE THIS IS GONE RIGHT?
DENNIS
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Reddeath210
Oct 6, 2015 08:20 AM
KO1
Aug 31, 2015 06:31 PM
