[PA] LT1 Long Block w/ 24x LS1 Conversion
Old Mar 1, 2012 | 06:12 AM
S10Wildside's Avatar
LT1 Long Block Assembly w/ EFI Connection's 24x LS1 PCM Conversion Hardware
$3,500.00
This 1996 LT1 engine has no run time after a stock rebuild that was completed on 2/8/2012. The block was machined 0.030", making the engine 355ci. The LT1 ignition system has been replaced with EFI Connection's 24x conversion hardware, making this engine ready for LS1 PCM control. Follow along with the installation of the 24x conversion on this engine at http://www.facebook.com/eficonnection.
Shipping is available for $350 and excludes Alaska, Hawaii, and International locations.
The engine is located in Erie, Pennsylvania. Please call 814-566-0946 or email mike@eficonnection.com.
Old Mar 1, 2012 | 07:23 AM
Mudluver27's Avatar
Car: 1988 Firebird
Transmission: 6-speed
Axle/Gears: 2001 ss 10 bolt 342's
Re: LT1 Long Block w/ 24x LS1 Conversion
Man I would love to do this to my LT1
Old Mar 1, 2012 | 07:57 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Go for it!!!!! Your Lt1 will love you for it.......
Thank you Eficonnection for an awesome product my ONLY complaint is that I have to give up my ABS
Technical support is top notch just like their products thank you Mike.
Old Mar 1, 2012 | 09:15 AM
It is true that you will lose the LT1 PCM ABS functions (spark retard), but customers have been reporting that ABS continues to work. We even had a 1996 F-Body customer who scanned the system with a Tech2 and did not find ABS codes in the background.
Old Mar 1, 2012 | 09:41 AM
Car: '88 Trans Am
Engine: 5.7L TPI
Hmm well once I am back up and running I will put my ABS to the test
dusterbd
Sep 29, 2015 08:40 AM
evilstuie
Sep 24, 2015 02:31 AM
