1.6 roller rockers 350 cams nib timing set bearings
im cleaning out the garage i have:
a single roller timing gears and chain-50
2 stock 350 cams nib-30 a piece or 50 for both
1.6 3/8 stud roller rockers with poly locks- 150
nib set of std. rod and main bearings-50
nib set of .020 over rod and main bearings-50
nib set of 350 cam bearings-30
t5 clutch assembly pedal and hydraulic master cylinder-100
will ship
will ship
Engine: 4++,350 & 305 CIs
Re: 1.6 roller rockers 350 cams nib timing set bearings
This should be posted in the classified section.
More info on the rockers ??
self alining or not ?? Brand??
My bad im pretty new to the site ill make sure next post is in right section im pretty sure theyre self aligning and comp ill double check tom. I wont be home tonight
forbsome reason there is no brand but i am pretty sire theyre comps theyre gold with black centers they are non self aligning and theyre 1.6 for 3/8 stud
