parting out 1988 iroc z28--tpi 5 speed 3.45 car
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: parting out 1988 iroc z28--tpi 5 speed 3.45 car
Is the car saveable?
Car: 89 iroc/90 iroc conv./06 ram
Axle/Gears: 3.27/3.27/3.91
Car: 1991 Camaro RS
Engine: 5.0 V8 305
Transmission: Stock Automatic
Axle/Gears: Stock...For Now
Probably a stupid question but does the 3.45 at the end of the title mean it has 3.45 gears in the rear end? If so I might be interested in that. If the price is right. I really shouldn't be spending money on that, I have to repair an exhaust leak and some leaking fluids, but...I may want it.
$300 picked up complete
Car: 1991 Camaro RS
Engine: 5.0 V8 305
I know theres probably a better place on the site to ask this type of question, but I'm going to ask here anyway. How difficult is it to replace the rear end? I have the stock 2.73 with drums in a 91 RS 5.0. My father and I aren't mechanics but we know our way around a car. Would it be easier just to bring it somewhere and have it installed or can it be done in the driveway? Thanks for the info.
Car: 1991 Camaro RS
Engine: 5.0 V8 305
I want it, from what I've been reading, it will help my acceleration but will destroy my gas mileage in overdrive and at higher speeds, like on the highway. I hate to say it, but right now I don't think I can because of the other issues. I need to get those cleared up so I have a good running and driving car before I start upgrading. If I can get my few issues cleared up soon and I still have the money I'll message you. Im going to bookmark this page. Thanks for the info and I hope I can get it eventually.
Axle/Gears: BW 3.45
Why can't I find any LB9/T5/3.45 beaters around me?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Cool. I need it, someone went clipper crazy on my harness in my '88.
Not sure when the next time is I'm heading down 495. What do you think it would cost to toss it in a box and send it to me ?
If it's too much maybe I can make it down next week.
Either way, hold onto it for me. I need it.
-- Joe
-- Joe
-- Joe
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 88 camaro, 87 TA
Engine: 454 stock, built 468 400hp+150 shot
Transmission: WC t5, m29 t56 spec stg3 clutch
Axle/Gears: 9 bolt 2.77, 9 bolt 3.70
i take it its a 9 bolt rear end??
how much complete??
how much complete??
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
How much for the trans, bell housing, peddles, and hydraulics?
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Was going to ask you about selling the shell, but then noticed you labeled the car as better for parts. Im looking for a really clean shell. thanks anyway.
Car: 89 Camaro RS
Transmission: 5 Speed
How much for the air cleaner assy shipped to 48723. Also need an egr solenoid.
Car: 88 IROC-Z
Transmission: 700R4-currently being mildly built
Axle/Gears: stock 2.73:( with limited slip
ok, I got a list of stuffs...
does the MAF have a 5 pin connector? if so, how much for the connector?
brake pedal switches? I'm in need of the brake light switch with the 3 pin connector.
how much for the throttle valve cable?
I may add more to the list if I remember more things I need
Car: 85z28(sold),91 rs, 15'Mazda3GT
Engine: 5.7L V8 350 (ZZ4)
Transmission: 700r4 rebuilt with kits+ vette serv
How much if its good shape-
Door panels, console lid, t tops headliner, the headliner light case, side bottom ground effects, rear bumper.
Really picky on condition on parts so best bet is to send pics
Car: 89 Camaro RS
I just need the top part and possibly the rubber boot. If you have that also.
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Need the fuel pump assembly prefered without pump I just need the gauge sender unit to work how much?
Car: 82 Z28
Engine: Vortec headed 350, lightly worked
Axle/Gears: LS style 7.5, torsen 3.42 disc
How much for the t5 torque arm bracket to 65401?
Car: '92 Camaro RS | '11 E92 335i
Engine: 305 TBI V8
Axle/Gears: Stock
need fuel lines from fuel rail to rubber hoses shipped to 19711 how much?
Car: 87 camaro z28
Engine: 383 stroker Holley Stealth Ram
Transmission: t5
Axle/Gears: 10 bolt 4:10 posi
Did u say 150 for the gears? Is that the whole center section or just ring and pinion? I have a 9 bolt set up just need the guts and brakes.
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
Looking for a decent black trim piece/bezel for the radio/heater ctrls. If you have one, send me pics and a price shipped to 44077. Thanks!
86IROC112
Aug 17, 2015 02:00 PM
mustangman65_79
Aug 11, 2015 03:17 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
