[NJ] Camaro Wheels w/Goodyear Tires
Car: 1986 Camaro
Engine: 383 Stroker
Transmission: Powerglide
Axle/Gears: 4.10
I got four camaro wheels and tires. The rims are 16 inch. and the tires are good year eagle ga 235/55/r16. Tires have a lot of thread left. I have the center caps, and lug nuts that will go with them. They came on the car when I got it and I have never drove on them just rolling the car around as I was building the car.I would keep them but I dont need them I just put Weld Racing Pro Stars all the way around.
Must be picked up
Located National Park, NJ 08063
Asking 400 obo
Photo of tires on the car
Must be picked up
Asking 400 obo
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
Re: Camaro Wheels w/Goodyear Tires
Will trade for these items.. Might need to group some items together or put cash on your end.
Comp Cams Solid Roller Cam (CCA-12-771-8) (Custom ground Small Base Cirlce)
Comp Cam Push Rods (CCA-7972-16)
Comp Cam Lifters *(CCA-891-16)
Throttle Cable Bracket (AED-6600)
Roll Cage (CEE-3130-K)
Lakewood Traction Bars (LAK-21700)
(2)Mickey Thompson Tires (26x7.5x15) (MTT-1573)
Proform Engine Dress up Kit (PRO-141-758)
UMI Lower Control Arm (UPI-2015-R)
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
Stuff I will trade for:
-Comp Cam Lifters *(CCA-891-16)
-Throttle Cable Bracket (AED-6600)
-COMP Cams Steel Thrust Plate Timing Covers (CCA-208)
-Proform Stamped Steel Chevrolet Valve Covers (PRO-141-751)
-Proform GM Licensed Chevrolet Air Cleaner Kits (PRO-141-752)
-Roll Cage (CEE-3130-K)
-Lakewood Traction Bars (LAK-21700)
-UMI Lower Control Arm (UPI-2015-R)
-Mr. Gasket Crankcase Evacuation Systems (MRG-6002)
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
SOLD 2 TIRES.
I have left
2- complete tire and wheels (tires in decent shape) 65 obo each
2- rims in good shape 35 obo each
I have left
