[NC] Completed TPI setup with injector harness and ECM
Car: 1998 Trans Am, 1992 Firebird
Engine: 402 LS2 stroker, 355 SBC
Transmission: T56 in both
Axle/Gears: 4.10 gear Moser 9", 3.27 9-bolt
TPI setup. In my way, been in my way for a while. It is complete, I have the injectors, throttle body, EGR, and fuel rail not pictured. Price also includes ECM and injector harness to use for swapping a TBI motor to TPI. All you'll need is a memcal. It is an 87 with the 9th injector, but you can just plug that hole and do without. Been cleaned and painted. $175. I can blast it and powdercoat it for a little extra.
Re: Completed TPI setup with injector harness and ECM
Oh, I am missing the distributor cover, but those are available cheap.
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
You said it comes with injector harness. Are you talking about the harness that goes from the ecm to the motor, sensors, injectors, ect.?
No, just the harness for the injectors. If you are swapping from TBI to TPI you can reuse the entire TBI harness, but wire these in place of the existing two TBI harnesses since TPI is batch fire.
Car: 1989 Formula
Alright now dude, it was already tempting when you had it on HPJ without the harness and ECM. I call dibs on this, you know how to get in touch with me.
It's yours buddy.
Sanjay
Aug 12, 2015 03:41 PM
