[WA] Parts Clear Out TAKE A LOOK
Old Jul 29, 2012 | 09:10 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
So ive got a ton of parts from my 89 that i need to clear out, prices are pretty good but make me an offer on whatever you like. All prices are without shipping if you wanna buy the part then get a hold of me and we can work out the details
1. V6/Iroc style air cleaner ***Sold***
2. V6 upper and lower plenum - $50
3. Power Steering pump - $20
4. AC Pump - $20
5. AC Lines $20, ******Or $35 for the pump and lines together
6. Delco Remy Alternator, dual fan setup - $40
7. V6 Radiator, great shape -$60
8. V6 Fan shroud no cracks - $30
9. Single Fan - $10
**(the radiator/ shroud can be used on any car together, ill sell the shroud, radiator and fan for $75
10. V6 700r4 trans inspection cover - $10 ( idk if it will work for v8 700r4)
11. Passenger side hush panel - $15
12. Radio Bezel no cracks - $20
13. Panel underneath steering column, no cracks - $10
***I also have various grey interior pieces, let me know what you need
Thanks for looking!!
Old Jul 30, 2012 | 09:44 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: Parts Clear Out TAKE A LOOK
More to add I have a drivers side interior door handle in the box still -$10
Automatic shift plate, no cracks or anything the prndl plastic has been repainted on the inside its hardly visible on the outside but ill let it go for 45 after seeing that, had it listed in a dofferent thread for 60, I drove the car for months and never noticed it until I pulled it apart
There is also a complete ac box that was properly removed available, pretty mug all ac components minus he condensor that mounts by the radiator
Anyone looking for a harness this one was jacked (sawed actually) from my parts car the other night, dunno why but unfortunately thanks to some tweaker its not available :/
Old Aug 3, 2012 | 04:14 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Bump air intake has been sold
Old Aug 4, 2012 | 01:34 PM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
do you happen to have the hard heater core lines? Also could I get a better picture of the A/C compressor fitting up next to a ruler? I'm wondering how it might work with my LT1 swap.
Old Aug 4, 2012 | 06:14 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
The hardlines were scrapped with the car I didn't even think to keep them, I yanked them on my car so when I came across them I just laughed and kept pulling other parts, ill have to take that picture for you but from what I can gather the ac conpressors were all the same across the board because it was an off the shelf item gm used in all their cars
Old Aug 5, 2012 | 04:53 PM
Car: 86 Camaro Z28
I'm doing an LT1 swap, and I was curious if they might fit on the compressor and bend just right for the lower position.
Old Aug 5, 2012 | 09:19 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
I can't desk for lt1 swaps, never done one but if this will fit the project its available
Old Aug 7, 2012 | 04:33 PM
Car: 86 Camaro Z28
I was looking at the part a little bit more, and it wouldn't work because the ports are switched from what I would need. Thank you though
Old Aug 10, 2012 | 01:08 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Bump
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
