Hydro Roller Cam/Pushrods/ETC
Old Sep 28, 2012 | 11:05 PM
91RsNate's Avatar
Car: 91 Camaro
Engine: 383
Transmission: th-350
Hey guys, still have some more stuff I need to get rid of. All the motor parts have less than 500 miles.
1. Herbert Hydro roller, will work in any late model style block that uses a cam retainer plate (vortec, LT1, TPI Motor) just by changing the pin. It has the short pin in it right now for vortec style.
Specs are 233/242 at .050 with .540/.555 lift with 1.5 rocker on a 109 LSA. Still have original box and cam card. I bought it new from herbert. Its a BILLET core. $130 OBO plus shipping.
2. Pushrods for Factory style Hydro roller lifters and cam. These are FACTORY length but .080 wall. Made by Comp (or so they say) for Jegs. They are a GREAT pushrod and look no different then my $150 comp magnum pushrods. $50 OBO plus shipping
http://www.jegs.com/i/JEGS-Performan...ductId=1558358
3. Pro Comp Gear drive timing cover setup. This is the Single idler built into the timing cover setup. Was on my new engine but Im swapping out for a belt drive. Few little dents and dings from prying the front face plate off. otherwise in great shape. New its $150 on ebay. Ill go $60 OBO plus shipping.
http://www.ebay.com/itm/GEAR-DRIVE-A...-/290690021607
4. Pioneer brand Head bolts, were in another motor I got. Less then 200 miles. only torqued once.. $15 plus shipping
5. Moroso Tall stamped steel valve covers, perimeter style. Grey in color. Some light dings and dents but nothing major. $20 Plus shipping.
7. SBC oil pan for 1 piece rear main motor. 7 quart side kickout style pan, fit good in my 91. Has hole in bottom where a rock hit it right smack dab in the middle of pan.. Wouldnt take much to fix it. Bout the size of a quarter. Price reflects damage. was new when i put it on motor, bout 500 miles ago. Dirt roads suck. $30 plus shipping.
8. SBC water pump for 91ish camaro or anything reverse rotation. was new 500 miles ago from oreilly. lifetime warranty model. $20 plus shipping.
9. Serpentine setup from 91 camaro. all brackets, pulleys and the p/s pump if you need it. Will work on price depending on what you need. $100 including p/s pump. $150 with a/c compressor.
10. SBC 880 4 Bolt main roller block. .030 over. was a fresh build 500 miles ago. Block was decked to 9 inches and square. Line hone, new cam bearings. Clearanced for 3.750 stroke (383).. has windage tray. All holes in good shape. Its ready for assembly after a quick wipe down. Sold crank and rods already. still have 6 pistons. Nothing wrong with block, would like to keep it but I have a 434 now and no need for this. $300 OBO Plus shipping or local pickup. willing to meet within 100 miles.
I also am parting a 91 camaro.. some stuff gone, just ask..
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
