[NJ] SBC/BBC Parts/Blocks/Transmissions
Car: 1994 Z28
Engine: 355 LT1
All prices are OBO unless otherwise listed. Making room in the garage & looking to do a (eventually forced induction) LSx/T56 setup. Will trade for said LSx parts, trans, drop out LS1/T56/harness/ecm + cash on my end. Will do package deals. Hard to believe how much money I have laying around tied up in parts (most I bought brand new over the past year) but I have no interest in building strictly a car that goes 1/4 mile and shuts down but rather a limited 1,000 miles/year on the street.
WILL SHIP SMALLER PARTS for +shipping.
350 block 2 piece rms flat tappet bored .030", splayed main caps/line honed, new cam bearings/freeze plugs/main bearings and clearanced for 3.75" crank (freshly machined) - $500
383 SCAT rotating assembly (Keith black cast aluminum 16cc dished (d-cup) pistons, scat forged 6" i-beam rods, scat cast lightweight 3.75" stroker crank 2 piece rear main seal, plasma moly rings.) All parts are new but the machine shop threw the crank out of balance - $600
Trick Flow Super 23* 195 aluminum heads with 62cc chambers, dual springs food for .600" roller setup, screw in studs, guide plates (new) -$1,000 FIRM
Trick Flow 1.5 roller rockers (new) - $120
Comp Cams 274/286 advertised duration 230/236 @ .050 .490"/.490" lift 110LSA flat tappet cam + lifters (cam & lifters are new) -$100
New Comp Cams double roller timing chain - $50
TH350 with B&M 2,200 converter (shifts perfectly fine) - $300
TH400 from 1970 monte carlo + new 34 element sprag (shifts perfectly fine) - $350
Hughes Manual Trans Brake Valve body for TH400 (new) - $350
700r4 with corvette servos (reverse doesn't like to work) & 1,400 stall converter - $100
B&M shifter for 4 speed forward (normal) pattern + cable - $100
SBC Victor JR intake (used) - $75
Ported 781 Oval Port Big Block heads (bare but ported and cartridge rolled although I don't know anything about them) - $150
S10 headmann V8 long tubes (69490) brand new - $200
69 camaro long tube headers (surface rust) - $100
MSD 6AL ignition box $150
This motor has a blown head gasket or intake gasket and oil has small amount of anti freeze in it. I do not know much about it, build has 20,000 miles on it. 1970's LT1 4 bolt block, told it was bored .030", healthy sounding cam, dart 200cc iron eagle heads, victor jr single plane, 1.52/1.6 roller tip rockers, new holley 750 cfm 4 barrel carb, non hei distributor, turned a 12.8 @ 108 in a 3200lb car with 1.9 60' times due to not having the proper converter. I'd rather sell it in this condition and in the car so you can hear it run - $1,200.
Nitrous Sniper Kit (10lb bottle full) for 4 barrel setup, used once adjusting the tune PART # 07001NOS still have all aprts + instruction manual. $300
Zex Perimeter Plate (PART # 82043) installed but never used - $150
NOS bottle heater/warmer (installed but never used) - $120
NOS blow down tube - $10
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
Re: SBC/BBC Parts/Blocks/Transmissions
You got any distributor for sale non hei?
is the vic jr and efi version?
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
what the deal with this stuff i sent you a pm and no responds is this stuff for sell or not i see you log on and make post else where this is some bull **** you should have a real forsale thread
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
I have had money sitting in my paypal for weeks for this guy... I want to give him my MONEY! I thought we had a deal, sent me pictures to my cell phone and all, just never got back to me. What give playa?
92rsvortec350
19
Oct 9, 2015 09:39 AM
Infested
Jun 15, 2014 10:32 PM
