Lots of go fast SBC Parts Holley, Edelbrock, Comp, Crane etc
Car: 1985 Z-28
Engine: 350 4bbl
Transmission: t-5
Axle/Gears: 4.11
Like the title says I just pulled my built sbc out of the 69 camaro to install a big block. So I have no use for these parts and all have to go.
Edelbrock rpm performer aluminum heads. 70cc chambers these will be prebuilt for you already complete with dual valve springs and comp cam roller rockers 1.5. These heads have maybe 1500k miles on them as the car wasnt driven much just to shows and back. if you want the part number for them edel prt is 60619. Bare heads go for 1100. Im asking 800 for everything.
Comp cams flat tappet cam and lifter sets I have two of them. They were used to test and see what cam we likes better. These both have maybe 100 miles on them. Im asking 150 each the comp part numbers so you can look up all the specs are 12-213-3 and 12-238-2
Edelbrock victory jr intake 100.00
Holley street avenger electric choke 770 carb. This carb was used to test our motor it is NEW with 0 miles on it literally took it out of box put it on car tuned it to the car specs and let it idle for a little bit. Chrome aluminum finish real nice. These go for over 400 new Im asking for 325
Accell hei distributor another one of those that we bolted on the car but prefered to stick with points. These will include everything ready to drop in and go. 120.00
Complete long block 4 bolt main block .60 over. I will have to get specs on the internals new timing chain with no run time on it.
All parts are still on the motor and if wanted I could make a package deal for the whole motor. If interested send me your offer. you can either email me
ohbehave3@hotmail.com or text me 321-305-8312
86IROC112
Aug 17, 2015 02:00 PM
