[TX] Dyno Don's Y Pipe
Old Jul 8, 2013 | 10:26 AM
Z28/ZR1's Avatar
Dyno Don's Y Pipe
First $50.00 plus shipping takes it.
This is a Dyno Don's Y Pipe that was slightly modified, but can easily be put back with some welding. It can also be modified to work with other headers that uses the same route.
Old Jul 8, 2013 | 10:59 AM
dmwracing42's Avatar
Car: 1984 Trans Am
Engine: 355
Axle/Gears: 10 Bolt, Torsen Diff, 3.73's
Re: Dyno Don's Y Pipe
You have a PM
Old Jul 8, 2013 | 11:15 AM
Z28/ZR1's Avatar
Originally Posted by dmwracing42
You have a PM
Responded.
Old Jul 10, 2013 | 12:09 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
sold?
Old Jul 10, 2013 | 07:17 AM
Car: 1984 Trans Am
Engine: 355
Originally Posted by obeymybird
sold?
No, if you want it it's all yours
Old Jul 10, 2013 | 07:33 AM
Z28/ZR1's Avatar
sold?
Not sold yet.
Old Jul 12, 2013 | 04:06 PM
codyscamaroz28's Avatar
Car: 1982 Z28, 1991 RS
Engine: 350 Carbed, 305 TBI
Transmission: 700r4, t5
Axle/Gears: 3.23s posi Limited Slip, 3.08 posi
Would it it fit flowtech shortly headers??
Old Jul 12, 2013 | 04:51 PM
Z28/ZR1's Avatar
If your exhaust is routed the same as the factory, you can make these work, as the main bends are in the right place. You may have to weld a matching header flange and re-clock the ends for a perfect fit, but this will still be cheaper than starting from scratch, or buying a new Y pipe. Also consider that this Y pipe has a ceramic coating, vs many of the Y pipes that don't.
Old Jul 12, 2013 | 11:12 PM
jas2730's Avatar
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
Shipping quote to 26757?
Old Jul 13, 2013 | 08:34 AM
Z28/ZR1's Avatar
Fedex wants $53.18 there. You must be in a remote area. This quote came in higher than places that are further away.
Here are the dimensions and weight.
Box dimension : 32x22x12 weight = 23 lbs.
Old Jul 13, 2013 | 10:48 AM
jas2730's Avatar
That's a little bit more than i'd like to spend.
Old Jul 13, 2013 | 11:17 AM
Z28/ZR1's Avatar
That's why I posted box dimension and weight, just in case you can find a cheaper way.
Old Jul 13, 2013 | 11:19 AM
jas2730's Avatar
Doesn't do me any good without your zip code.
Old Jul 13, 2013 | 11:43 AM
Z28/ZR1's Avatar
75006 business address which sometimes helps with the cost.
Old Jul 13, 2013 | 05:34 PM
jas2730's Avatar
I tried a couple places but can't get the price down without cutting it to fit in a smaller box.
Old Jul 16, 2013 | 08:57 AM
Z28/ZR1's Avatar
Bump
This is really a great deal for someone in need of a Y pipe.
MustangBeater20
Oct 29, 2022 09:20 PM
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
TheExaminer
Aug 26, 2015 04:59 PM
Out-Cast
Aug 22, 2015 07:49 PM
