Final parts clear out
I am clearing out all 3rd gen stuff I have collected over the years. Listed many different places so call or PM for exact up to date status. If it is big and bulky I won't ship and will put local pick up only. Paypal for payment or cash for local pick up. All prices obo and do not include shipping. Will separate components to meet your needs? Will add and delete as I sift threw what's left so let's get started. All parts located in Mid Missouri
All parts for T5 conversion: used bell housing, new 4th gen hydraulics, new hays clutch, pressure plate and throw out beating, new lightweight steel fly wheel, used pedals, new clutch fork and boot, new GM shifter seal $500 or will separate
MSE/Macho Tri Y Headers NOS, have some shelf wear, few dents nothing major and paint missing, light surface rust $200 may ship
Custom IMSA 82-92 Trans Am double bulge hood, one of a kind made by Cervini. Still in shipping plastic. $650 local pick up only
Northern 31 x 19 2 row radiator with shroud and dual 10" fans and fan switch kit All new never used. Radiator has some scratches on side tanks from being installed. $250
New Fenders trans am with vent cut out both LH and RH new aftermarket still in protective cardboard sleeves. $175 each local pick up only
RH Serpenteine Bracket 88-92 with air by pass pulley $65
March Perforance Pulleys(New take off) Crank and Alt. with Goodyear Gatorbck Short belt (new) for 88-92 only $75
GM steering gear, reman, never used, fast ratio, preload and lash already set.
$100
Gas tank, refurbished, GM original so fit is great, filler neck reinforced, urethane painted gray, brand new Gm fuel pump installed with good used sender. $100
Local pick up only.
Mallory fuel pressure regulator with return and all ss braided lines for FI to carb conversion, Earl's connecters to stock fuel lines and 6AN to fuel connector at carb, never had gas in them. $125
Trans AM tail lights LH, RH and center piece, tail lights $75 each, $50 for center
Lots of parts from 88 trans am: doors, gauges, dash components, radio pod, wiper motor, head lamp motors, bumpers, gfx, rear hatch glass and deck lids(1 for wrap around, 1 for MSE spoiler), front 32mm and rear 24 mm big sway bars with new Gulstrand bushings, and energy suspension end links.
Joe
573-823-3893
$100
Local pick up only.
Joe
573-823-3893
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Re: Final parts clear out
some nice stuff on here, have a camaro automatic shift **** by any chance?
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
Can you post a pic of the tri y headers
Sorry no camaro shift ****.
I will fulfill all request on a daily basis in the evening so check back daily.
Thanks everyone for your interest.
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Got a pic of the LS1 driveshaft? Will you ship? Vehicle it may come out of? thanks.
Radio pod good used condition, upper front mount has crack in it but can't be seen once mounted. Includes face place. $50 plus shipping
Trans, also includes energy suspension trans mount
I can put together a complete swap with, bell, clutch, pedals and hydraulics for a package deal.
Fresh, GM AC Delco reman steering gear fast ratio, 2.5 turns to lock, never used still has plastic plugs in ports, includes pitman arm. $100 plus shipping.
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
how much for the serpentine setup minus alternator and ps pump shipped to 71047?
thanks, Greg
thanks, Greg
March performance pulleys crank and alt. part # 4000-08 and correct shorter Goodyear Gatorback belt. Fit all 88-92 V8 Camaro/Firebird
Pulleys have been mounted but never run slight powder coat chipping where bolts rubbed otherwise as new, belt still in sleeve. $75 plus shipping
