[NJ] 355 Heads/Parts/Block
Car: 1994 Z28
Engine: 355 LT1
Everything minus the intake manifold is new in the box. Rotating assembly will need to be balanced.
Trick Flow 195cc aluminum heads with 62cc chambers, set up with .600" lift springs.
350 roller block, 4 bolt main, bored .030" - needs final hone. Comes with spider plate, dog bones for lifters, rear main seal adapter and the oil pan. Block was tanked, magnafluxed, bored, cam bearings & freeze plugs were removed.
Scat 4340 I-beam "pro comp" rods with 7/16" ARP rod bolts, Scat 9000 series 3.48" crank, Probe FPS forged flat tops with 4cc reliefs, King Engine rod & main bearings, Mahle plasma moly piston rings, Comp Cams 1.5 ratio aluminum roller rockers, Edelbrock Victor JR intake manifold.
Looking for $2,500 OBO. I also have a NOS Sniper nitrous kit with a full bottle, bottle warmer and a 3 month old Holley 750cfm 4 barrel carb.
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 355 Heads/Parts/Block
if you decide to part separately I have interest in the cylinder heads if for centerbolt intake manifold, let me know.
Engine: gone
Transmission: gone
Axle/Gears: gone
but are you interested in parting out and how much for the heads?
codeysabatini
Nov 10, 2015 04:07 PM
darwinprice
17
Oct 11, 2015 11:51 PM
