[Sold] NEW! Spohn 82-92 Adjustable Torque Arm - T-56 Transmission (93-97 Fbody)
Old Aug 20, 2013 | 07:51 AM
al3srg0d's Avatar
Car: Cameron (The Camaro)
Engine: SBC 385 Stroker
Transmission: Stage 2+ T56 Six Speed
Axle/Gears: 3.42 Richmond Gear Locked Posi
This was purchased a few months ago for a build I was working on and bolted to the car, ended up going a different route so I won't be using this setup. It is brand new and has never been on the road, after options and shipping I paid just over $500 for the setup. I am willing to let it go for $375 shipped to the lower 48, includes driveshaft safety loop and the color is black.
If interested shoot me a PM here or you may call/text 262-327-2453 or email jinxed@gmail.com, thanks!
More information
http://www.hawksthirdgenparts.com/pr...2dBody%29.html
This kit is for installing a T-56 transmission from a 1993-1997 F-Body into a Third Generation F-Body. The kit includes the transmission crossmember required to install the T-56 transmission, along with our crossmember mounted adjustable torque arm. This kit makes the T-56 swap an easy bolt right in installation!
If you want serious performance, handling, and traction when you're at the dragstrip, AutoX, or road racing; then you need a Spohn Performance fully adjustable torque arm, here's what it'll do:
Attaches to the rear axle and controls rear end torque during acceleration, transferring this energy into the tires, increasing straight line traction
Reduces nose-dive during braking
Eliminates wheelhop
Increases sidebite during corner exit acceleration
Bolt-on system does not require complete interior removal as with other kits
No fabrication, welding or drilling required - 100% bolt-in installation!
Removes the torque arm pivot point from the rear of the transmission to the supplied crossmember
Changes the instantaneous center and leverage point from stock
Provides adjustable pinion angle
Poly version utilizes polyurethane front mount to keep noise at a minimum
Rod ended version utilizes a chrome moly spherical rod end front mount for those who demand the best bind-free performance
Build Specifications:
Constructed of 1.25" o.d. x .120" wall DOM (drawn over mandrel) seamless mild steel tubing
TIG welded 4130 chrome moly threaded tube adapters
Heavy-duty 3/8" thick steel rear housing mounting plates
Heavy-duty mild steel transmission crossmember with integral torque arm mounting system
Polyurethane bushing front mount for minimal road noise, Grade 8 hardware is supplied. Integral grease fitting allows for lubrication of the polyurethane bushing
Rod ended version utilizes a chrome-moly spherical rod end front mount for the ultimate in bind-free performance and strength. Grade 8 hardware is supplied
Unique rotating front torque arm mount, this system allows the torque arm to travel fore/aft which is VERY necessary with a torque arm suspension system. Solidly mounting the front of the torque arm causes the suspension to bind and hurts your car's handling drastically. The front rotator tube has an integral grease fitting to allow for proper lubrication.
Rear of torque arm mounts to the 3/8" thick steel rear housing mounting plates via two 3/4"-16 NFT x 5/8" bore x 7/8" thick solid steel rod ends. These are solid rod ends, not spherical bearing rod ends, so noise is of no concern. Grade 8 - 5/8" bolts and 5/8" nylock nuts are supplied.
Integral Pinion Angle Adjuster between the bottom rear solid rod end and the bottom rear torque arm tube allows for easy pinion angle adjustment. A simple turn of the wrench will give you 6 degrees of pinion angle adjustment, it's that simple.
Entire package is a complete bolt-in assembly using existing mounting points on the vehicle. No drilling or welding is required!
NHRA rules require a driveshaft safety loop on any vehicle running quicker than 13.99, or on any car running slicks. NHRA rules call for a loop with at least .250" wall thickness, located no more than 6" from the front u-joint. All Spohn Performance driveshaft safety loops meet every NHRA specification requirement in both build construction, and mounting location.
Available powder coated red or black.
Now offering the option of getting your torque arm with a front and rear driveshaft safety loop. NHRA rules call for a front driveshaft safety loop to prevent catapulting of the vehicle in the event of a front u-joint or shaft failure. While a rear u-joint or shaft failure will not catapult the vehicle, it will take out anything in it's way, ie. rears, suspension components, brake lines, floor boards, etc. Protect yourself, and your investments, and play it safe by containing the front and the rear of the driveline.
Old Aug 20, 2013 | 11:59 AM
Sanjay's Avatar
Re: NEW! Spohn 82-92 Adjustable Torque Arm - T-56 Transmission (93-97 Fbody)
PM Sent!
Old Aug 20, 2013 | 02:46 PM
al3srg0d's Avatar
replied!
Old Aug 20, 2013 | 05:44 PM
al3srg0d's Avatar
Sold to SanJay, enjoy
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
zayne0
Aug 24, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
