[Sold] COMPLETE HEADS/CAM LT1 swap or part out..
Old Aug 30, 2013 | 04:16 PM
LT1IROC-Z's Avatar
Car: 87 IROC
Engine: LQ9 6.0
Im installing a built 6.0 LSX in my car so I am selling the COMPLETE LT1 swap out of my car to help fund that project,or ill part it out if I get enough interest's..with that said,heres what its got done to it: Its a 94' f body LT1 out of a 94' firebird formula,its bored .030 over to a 355 with Probe forged 2256 flat top 2 valve relief pistons and yield approx 11.7:1 compression, has stock casting aluminum LT1 heads that I had ported by Lloyd Elliot,theyre the LE1's and the specs on those can be found here: http://elliottsportworks.com/?page_id=51 ,the intake is a stock casting LT1 intake and is lightly ported to match the LE1 heads(done by me),also has a Proffesional Products 52mm throttle body, CSR electric water pump, Mellings high volume oil pump, Chevrolet performance 1.6 full roller rockers, Chevrolet performance LT4 HOT cam, Ford Motorsports 30lb injectors, MSD blaster coil, Summit racing 8.5mm wires, LE1 a/c delete pulley, BBK underdrive pulley, Ported stock maf sensor, pcm was tuned by Ion solton @ madtuner.com and is ready to drop in and go,..this is a very strong runner,it ran 12.2@114mph in a 3400lb car(Approx 450-475 crank horsepower),and I drove it to and from the track..very streetable and very reliable,has about 4,000 miles on it since the build,asking $1,800 for the complete swap but am willing to part it out if I can sell the heads first...,here's what I would like to get for individual parts,(IF THE HEADS SELL FIRST):
*LE1 Heads:$900
*Chevrolet Performance LT4 HOT cam:$150
*Chevrolet Performance 1.6 full roller rockers:$150
*Professional Products 52mm throttle body:$125
*Ford Motorsports 30lb(redtop)injectors:$125
*CSR electric water pump:$125
*BBK Performance 1591 underdrive pulley:$40
*Probe forged 2256(4.030in bore)piston's on stock LT1 rods:$200
*LT1 intake(stock/lightly ported):$85
*MSD(8226)Blaster coil:$35
*Summit Racing Street & Strip 8.5mm Ignition Wires:$50
*LT1(.030 over)engine block:$150
*LT1 Crankshaft:$100
*94' LT1 PCM:$100
Old Sep 1, 2013 | 09:54 AM
LT1IROC-Z's Avatar
Car: 87 IROC
Engine: LQ9 6.0
Re: COMPLETE HEADS/CAM LT1 swap or part out..
Bump
Old Sep 2, 2013 | 01:18 PM
LT1IROC-Z's Avatar
Car: 87 IROC
Engine: LQ9 6.0
Bump
Old Sep 3, 2013 | 06:18 PM
LT1IROC-Z's Avatar
Car: 87 IROC
Engine: LQ9 6.0
Bump
Old Sep 3, 2013 | 06:38 PM
inthe10s's Avatar
Would you sell the probe pistons without the rods?
Terrell351
Jun 13, 2021 01:13 PM
midge54
Jan 29, 2017 07:00 PM
Casey Meyers
Mar 2, 2016 10:46 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
