355 700r4 exhaust umi msd
1 Post
Car: 86 iroc
Engine: Iron 408 LS3 combo
Transmission: Ram10 T56
Axle/Gears: 3.73 10 bolt :)
engine: 15k
-350 4 bolt main 1 piece rear main from the 90's roller block rebuilt by precision engines in canada by a family known builder, all rebuilt but all stock.. 30 over
-edelbrock rpm heads #60999 with arp head bolts
-edelbrock flat tap hydrolic cam #7102
-edelbrock rpm air gap intake #7501
-crane cams full roller aluminium rockers #11744-16
-double roller timing chain
-stock water pump + 160thermostat + housing
-melling high volume oil pump
-moroso 5qt oil pan
-trick flow harmonic balancer #TFS-19000
-edelbrock 650cfm avs #18064
-msd pro billet distributor # 85551
-msd 6al2 ignition box #6421
-msd blaster 2 coil + bracket
-msd street fire wires + wire looms
-chrome valve covers + timing cover
-stock starter
-stock flexplate
-energy suspension poly engine and trans mounts
-lokar throttle cable + bracket
-lokar tvc cable
transmission:
-700r4 5k also built by a builder in canada
-pro-built street/strip rebuild kit #SSRK700L87
-competition engineering trans+converters 2800 stahl converter
-umi crossmember munted tubular adjustable torque arm
-umi crossmember with driveshaft loop
-custom built 3in driveshaft with spicer joints
-edelbrock shorty headers + y pipe
-stock hallow cat
-hooker cat back #16820HKR with tips
cant think if im missing anything here but im open to offers
$3500 obo
-moroso 5qt oil pan
-stock starter
-stock flexplate
-lokar tvc cable
transmission:
-stock hallow cat
$3500 obo
Car: 1982 Z28, 1991 RS
Engine: 350 Carbed, 305 TBI
Transmission: 700r4, t5
Axle/Gears: 3.23s posi Limited Slip, 3.08 posi
Re: 355 700r4 exhaust umi msd
what kinda of air breather you have i need one lol.
1 Post
Car: 86 iroc
Sorry guys haven't been on here in a while, if I can sell the Trans then I will start separating the rest
86CamaroDan
09-29-2015 10:08 PM
TheTraut88
09-07-2015 05:22 PM
