[PA] Go fast whole car part out
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Everything has less then 1000 miles
91-92 Front clip 300$ (Clip include both headlight buckets, working motors, bumper, reinforcement, marker lights, Air Dam, and reinforcement filler)
GTA hood - 150$
Fenders ( Reman ) - 75$ each
Doors - 100$
Rear hatch - 100$
Rear 1/4s - 200$ each
Various Interior parts - make offers
Engine:
1500$ for long block
Long block has Cometic head gaskets, GM Performance Head bolts.
CompCam XE294H-10 With CompCam 1.6 Full roller rockers
4bolt main block
Eagle 383 rotating assembly
Edelbrock E-tec 210 heads
GM performance front end accessory kit 350$
Canton Road Race Oil Pan 15-244 will come with pick up and Melling Select High Volume oil pump - $250
Tuff Stuff high flow chrome water pump - $100
GM Performance Starter #12361146 - 180$
Hydratechbraking Bolt on Hydroboost setup, Includes everything but P/S pump - 600$
GM coolant bottle, dirty, but NOT YELLOW! 25$
Painted spindles, New calibers, pads, rotors, bearings, rubber brake hoses - 125$ for both sides
BMR battery relocation bracket, Scratched and looks kinda beat - $50
Unused UMI Solid Motor Mounts #0051 - 45$
Will do package deals
Transmission 700R4; 1250$ OBO
Complete Raybestos Stage One Friction Kit with 3-4 Kolene steels
Replaced all seals and gaskets
Wide Raybestos Pro Series Band
Re-manufactured forward sprag assembly with updated 29 element sprag
New ACDelco reverse input drum
"Beast" sun shell
ACDelco 5 pinion rear planetary gear
Corvette governor
ACDelco governor cover
Steel chrome pan with drain plug
One wire TCC lock-up switch
.500 boost valve
3-4 upshift kit
ACDelco accumulator pistons
Sonnex 2nd gear "Super Hold" servo
Shift technology 4th gear "Super hold" servo with billet cover
Suspension;
UMI front A-arms Item#2031 $400
Jeep steering shaft - $30
Wonderbar - $40
17x9 Repro ZR1 wheels
Nitto NT05 Drag Radials in back
Falken Tires is front
Wheels and tires - $950 OBO
Formula Wheels with OKAY Falken ZE912 Tires 400$
Make offers. I won't ship big parts.
Prices don't include shipping.
Will also entertain trades for legal firearms and ammo
GTA hood - 150$
Doors - 100$
Rear hatch - 100$
Engine:
4bolt main block
"Beast" sun shell
Corvette governor
.500 boost valve
3-4 upshift kit
Suspension;
Wonderbar - $40
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Re: Complete High Performance Part out
What color are the lower control arms?
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
how much for dash pad?
prices and pics on aluminum radiator and borla exhaust
Car: 88 Firebird.
Engine: 383 HSR
Are the control arms adjustable or solid?
Car: 88 Firebird.
Engine: 383 HSR
Car: 88 Firebird.
Engine: 383 HSR
Tear down started, more parts added. Everything on car for sale, including shell.
Car: 1988 Iroc T-top
Engine: 350 w/typical bolt-ons
Transmission: 5 speed
Axle/Gears: 3.42 zexel, TEN chromoly 28 splines
What was your impression of the Edelbrock E-210 heads? I'm in the market for heads, and I like these, but Edelbrock's posted flow #s didn't impress me much....decent intake, but the exhaust/intake relationship flow numbers weren't great.
Not too many people have given reviews on these heads, dunno if that is a bad sign? Or just 'cause there not popular?
What did you think?
What did you think?
Car: 88 Firebird.
Engine: 383 HSR
What did you think?
What did you think?
Replied to your PM
Car: 88 Firebird.
Engine: 383 HSR
Radiator sold.
Still have tons of stuff!
Car: 88 Firebird.
Engine: 383 HSR
all suspension and radiator back for sale.
Car: 88 Firebird.
Engine: 383 HSR
Car: 88 Firebird.
Engine: 383 HSR
Steering box and Trans cooler set up sold.
Car: 88 Firebird.
Engine: 383 HSR
Shocks and upper strut mounts sold! Thank you
Car: 88 Firebird.
Engine: 383 HSR
Nobody wants a bolt on Hydraboost setup?!
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
I am intersted in the Hydroboost. Would it be easy to use with my LS1 power steering pump and work well with my C5 brakes? PM me best price shipped to 23456. Thanks
Car: 88 Firebird.
Engine: 383 HSR
Engine was built by me. Your welcome to look at it, pull oil pan or a cap
Car: 88 Firebird.
Engine: 383 HSR
I don't. When I built it, I didn't intend in getting rid of it. I didn't save paper work. I can find the part numbers for the rotating assembly though.
Car: 88 Firebird.
Engine: 383 HSR
Car: 88 Firebird.
Engine: 383 HSR
