[CA] Rowdy 383 Solid Roller motor carb to pan
Old Nov 19, 2013 | 11:51 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
200 mi only pretty fresh
This motor is perfect, no funny noises knocks smoke, nothing. I spent yrs and tons of $ putting it together.
All the good stuff almost every part has had additional machining porting polishing, something done to it. Ill just post some basics too much to mention. If youve built one from scratch before youll see the value here.
This is not a bolt together pos ebay kit.
Balance job is incredible
brand new GM 4 bolt block .040 studded
4340 3.75 crank
Manley Pro Race H beams 6 in
Probe domed forged floating pins
Hv melling worked over
Milodon 7 qt pan
Dart 230cc heads worked by Tony Mamo@AFR
Have all paperwork on them.
Jesel 1.6 shaft rockers 10 deg locks oil return holes worked etc etc etc
Isky custom solid roller 260/268@050 640 lift 108lsa has fuel pump eccentric std base cir billet
Also have a like new Custom Comp SR 250/254 670 lift 110 Ill throw in if youd like to change it for a little milder app. has 60 mi on it.
Designed also by Tony have Cam card to prove
Crower severe duty lifters, Manley pushrods
Team G fully ported by yours truly
AED 850 Carb (in pic still had the old Holley on it
All polished ARP stainless hardware
Evrything aluminum or stainless externally I polished
True 11.5:1 compression
Can run 91 pump with 34 deg timing or run better gas for 36-38 deg
With a vacuum can power brakes work great
Very driveable despite the radical sound
This is not a motor to lug around in OD at 1500
Makes acceptable torque for cruising around, screams upstairs. Youll need a sticky tire period
Comes with acessories pictured cust alt ps etc etc. Have over 2000 alone in that setup. Not cheap summit stuff it will hold up to rpm.
Complete carb to pan ready to drop in and run
Motor in car currently just sitting
You arrange shipping
91311 zip
$8500 FIRM have WAY more into it than this
Or 8k I keep the access/carb
Sorry cannot take less or part out for now.
Old Nov 21, 2013 | 08:24 AM
Axle/Gears: 4.11
Re: Rowdy 383 Solid Roller motor carb to pan
Old Nov 22, 2013 | 08:50 AM
Axle/Gears: 4.11
Taking some heat from another site over the price no dyno sheets etc. If youre looking for the most power/$ there are better deals...or ads promising it anyway.
If you want a hot small block with good parts/machining that hasnt been beat to death with no issues might be for you. Ya get what you pay for.
midge54
Dec 27, 2019 04:14 PM
junkcltr
Aug 2, 2019 11:12 PM
theshackle
Mar 5, 2017 06:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
86White_T/A305
Aug 17, 2015 12:16 AM
