[GA] factory 4 speed T10 conversion parts ... NO TRANS NOR BELHOUSING !!
Old Dec 3, 2013 | 08:11 PM
TVP122's Avatar
pedals ...
linkage ...
steel drive shaft ...
factory shifter with mounting bracket ....
hurst shifter MOUNTING BRACKET ONLY ...
cross member ....
I'd take $200 on all ... plus shipping ....
MAKE OFFERS !!!!
Old Dec 23, 2013 | 09:24 PM
TA Daddy's Avatar
Car: 87 Trans Am
Engine: 305 for now working on 400 sbc
Transmission: 5 speed
Axle/Gears: stock for now
Re: factory 4 speed T10 conversion parts ... NO TRANS NOR BELHOUSING !!
pedals ...
linkage ...
cross member ....
MAKE OFFERS !!!!
What do you to have for the drive shaft and cross member??
Old Dec 24, 2013 | 08:36 AM
TVP122's Avatar
huh ? the ones that came in a 1982-1983.5 4 speed car ?
Old Dec 24, 2013 | 09:54 AM
TA Daddy's Avatar
Car: 87 Trans Am
Yes, the 4 speed stuff. I am putting a mid 70's super t10 in an 87 t/a behind a 400 sbc
Old Dec 24, 2013 | 10:02 AM
TVP122's Avatar
you've got A LOT of home work to do ....
this stuff only works with the T10 that came in a 1982-1983.5
you'd be better off with an older T10 or muncie ...i.e. they are shorter !
Old Apr 7, 2014 | 12:03 PM
TVP122's Avatar
TTT
Old Apr 7, 2014 | 12:27 PM
TA Daddy's Avatar
Car: 87 Trans Am
I have everything worked out except the Driveshaft.... I made a mount for the shifter to mount it in the same location as the Factory 4 speed shifter that came in the 82 - 83 f body's, I have a mount for the clutch slave or I have a hydraulic throw out bearing, so the missing link at this point is the drive shaft. the Super T-10 is about 2 inches shorter then the T-5... I know the tail housing is a different shape, having the shifter mount on the top right side (as instead of the bottom left side). But I figure they did not make a different tail shaft.
Old Apr 7, 2014 | 02:04 PM
TVP122's Avatar
you'll need a custom drive shaft too ......
believe it or not ... EVERYTHING is different on a stock 82-83.5 setup ..... the old 72-81 T-10's don't fit correctly ....
1992 Trans Am
May 10, 2023 07:19 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
rh76camaro
Exterior Parts for Sale
Aug 6, 2015 08:57 AM
