Used 342 ring and pinion and 4th gen 10 bolt housing posi+ 28spine axles
Car: 86 iroc
Engine: Iron 408 LS3 combo
Transmission: Ram10 T56
Axle/Gears: 3.73 10 bolt :)
Stripped apart good condition 3.42 ring and pinion, auburn style posi with broken tooth on 1 spider gear , housing from disc brake 4th gen with abs, no backing plates also 4th gen 28 spline axle shafts
50$ for ring and pinion
100 bucks for everything Adam 810-772-0073
Pick up only
Pick up only
Car: 86 iroc
Re: Used 342 ring and pinion and 4th gen 10 bolt housing posi+ 28spine axles
Bump also will throw in 28 spline 4th. Gen axle shafts rear end cover and a new cover gasket 100 bucks
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
