[TX] Crane Roller Hyd. Camshaft
Cam was run on the dyno only. And I decided to go with a smaller camshaft better suited for turbo application.
Crane Hyd. roller Cam. Small Base Circle (a must for stroker engines) pressed on gear, which means no need for a melonized gear.
Crane Cams Part number : 109641
Cam specs: 234/242@.50
Lobe separation : 112
Lift: .539-.558 = with 1.6 rockers .575-.595
Compression : 10.0-11.5
Power range : 3000-6500
Dual pattern rough idle. auto requirement :3000 stall converter
Advertised : 296/304
Firm $200.00 plus shipping.
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Re: Crane Roller Hyd. Camshaft
This is a 5 year old thread 🙄
KO1
16
Oct 15, 2015 05:00 PM
