[PA] 310 ci short block (rebuilt) low miles/ other parts
Old Apr 2, 2014 | 06:58 PM
dpmalibu's Avatar
1) 305 short block bored .030 over (rebuilt)w/ approx. 15k miles on it. Motor had 8.39:1 comp w/ 64cc heads. Has mild cam (specs unknown). Stock crank and rods, Mellings oil pump. Asking $200 firm
With 58cc heads compression would be 8.95:1
2) Camaro exhaust manifolds. All A.I.R tubes holes are welded shut. $40
3) Motor mount brackets $15pr.
4) misc alternators $20ea
5) GM High torque starters for 168 tooth flywheel $25ea
6) Edelbrock Performer intake. Dirty but all threads are good $45
7) Edelbrock 600 cfm #1405 carb (manual choke) $60
8) aluminum 5 rib pulleys (water pump, crank, alternator) $40
9) aluminum 3rd gen radiator $50
10) brand new (fluid cooler). can be used as a oil coiler or trans cooler $35
11) Ford Taurus electric fan $25
located in Hatboro,Pa
make offers everything must go!!!!
Old Apr 3, 2014 | 08:49 PM
marki's Avatar
Car: 92 camaro rs
Engine: 305 t.b.i.
Re: 310 ci short block (rebuilt) low miles/ other parts
Hi, is the radiator still available? may i please see a picture? pm sent also
Old Apr 3, 2014 | 09:39 PM
kitt462d's Avatar
Car: 1985 TA
Engine: 350 Carb
Is the 310 a 1pc or 2pc rear main?
Old Apr 3, 2014 | 10:01 PM
inthe10s's Avatar
This is from his other for sale thread
Old Apr 4, 2014 | 12:41 AM
dpmalibu's Avatar
Thanks Inthe10s. It is a 1pc RMS motor. Radiator still for sale. Pm sent
Old Apr 4, 2014 | 07:04 AM
TennesseeIroc-Z's Avatar
Car: 1988 Iroc T-top
Engine: 350 w/typical bolt-ons
Transmission: 5 speed
Axle/Gears: 3.42 zexel, TEN chromoly 28 splines
I'm interested in the radiator and carb as well. Carb in ok shape?
Old Apr 4, 2014 | 07:19 AM
dpmalibu's Avatar
Yes. The carb worked fine. Check my other post in this forum for pics.I will try to post some today
Old Apr 5, 2014 | 06:07 PM
dpmalibu's Avatar
$175 for the short block
Old Jun 28, 2014 | 12:31 PM
dpmalibu's Avatar
price dropped to $150
Old Jun 29, 2014 | 03:22 PM
dpmalibu's Avatar
motor is sold
anesthes
Mar 10, 2016 10:35 PM
Reddeath210
Oct 6, 2015 08:20 AM
camaro71633
Sep 1, 2015 10:24 AM
BBSDesigns
Aug 11, 2015 07:39 PM
1nastygta
Aug 8, 2015 07:38 PM
