single plane efi set up
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
This is a single plane intake with a 1000cfm throttle body with progressive throttle linkage, fuel rails, fuel pressure regulator, bosh blue top 24# injectors. $400
Engine: forged 350
Re: single plane efi set up
It was from electromotive engine controls wintec 2 system
the ports on the throttle body are 1 3/4 the ports on the intake are 2" tall and 1 1/8 wide with a lot of meat for porting. I also have some other parts from the system if you would be interested like the coil packs and the billet electronic trigger master distributor for use with coil packs.
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Where can I get more info on the system?Deffinately interested
LT1Formula
20
Nov 14, 2015 12:02 AM
beachrodder
Aug 25, 2015 08:05 AM
