[CA] Procharger P600B
Old Jun 29, 2014 | 03:43 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Procharger P600B
P600B kit for 88-92 TPI F-body's
Comes with 2 pulleys(12/8psi)
SOLD
fuel pump lines
FMU lines
Old Jul 1, 2014 | 10:34 PM
Benc1's Avatar
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
Re: Procharger P600B
What kinda miles on the kit?
Old Jul 2, 2014 | 07:38 AM
rwstegne's Avatar
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
Do you have a before and after dyno sheets? What type of gain did you get? Did you do a build thread on your setup? Do you have details on your setup? I have been interested if it would be worth doing to my 89 TPI.
Old Jul 2, 2014 | 12:14 PM
kairles's Avatar
Engine: 383/LGX
I bought it used and the seller had just rebuilt it. I put about 2000 miles on it.
No, never did any of that. It was on a 90 formula LB9/auto w/ 2.73 rear. only real mods was edelbrock headers, magnaflow cat, 3" exhaust w/ a spintech muffler. ran 14.7@90 N/A never got a good tune or 1/4mi run when S/C. I did run door to door with a C5 ZO6 up to about 90 or so(street) before I let off. was running 10psi(12psi pulley). From the research I did the p600b would be good for stock or slightly modified(bolt ons) motors. So if you plan to build a motor around the S/C, this isn't the S/C you wanna get.
sleprock
Oct 1, 2015 09:39 AM
sleprock
Sep 24, 2015 04:33 PM
-=Z28=-
Sep 24, 2015 10:21 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
