[NY] World Class T5 swap, dual radiator fans and 91 Z28 part out
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
I purchased the car for some parts my friend and I needed so I would like to sell off some of the items neither of us want to recoup my costs.
First is a complete world class T5 swap the car has 127,xxx miles on it and the transmission appears to be original. The car was unregistered and didn't come with a battery when I got it so I have not had the opportunity to test drive it to verify transmission operation. I'm looking to sell everything as a package
The master cylinder needs to be replaced and there are a few hot spots on the flywheel. Personally I wouldn't to a swap and reinstall used wear item components, but I will include every component on the car related to the 5 speed minus the steering column.
$600 obo for the complete swap
I was able to remove the factory dual fan set without damage. 60 obo
If you are looking for any other parts off the car other than wheels, hood, ECM and harness or the deck lid/ spoiler please post and ask.
I'm having issue uploading the pictures if somebody have help with that.
- pedals
- starter
- flywheel
- clutch and hydraulics
- bell housing
- shifter
- transmission
- torque arm bracket
Engine: 355, 408
Engine: 355, 408
Re: World Class T5 swap, dual radiator fans and 91 Z28 part out
92RS... I replied to the PM you sent me.
Any interest / need for other parts out there?
I am doing a similar swap with a LS motor and would be interested in the pedal assembly if you choose to separate. I am using the 98 camaro hydraulics so the rest is not needed
Thanks Bobc
Thanks Bobc
Engine: 355, 408
how does $50.00 sound my e mail is modernclassicsga@aol.com
Engine: Cammed 6.0L LSX
Engine: 355, 408
I don't know if it works and I already pulled the engine bay harness. I'll have to see if I can use a jump pack to find out if the motor is still good.
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
map sensor bracket that bolts to the tpi plenum? Thanks
Engine: 355, 408
Bob Catapano
265 Parkmont Court Roswell GA 30076
send me yours and I will get the money to you for the pedal assembly and for the shipping. Try to see if you can get them in a Priority mail box its the cheapest flat rate out there
Engine: 355, 408
Make me an offer on it.
Car: 84 z28 CMC1 spec
Engine: L69
Transmission: BW T5
Axle/Gears: 3.45 9bolt
Hi, would you be willing to sell just the transmission, and ship to MI? I really only need a 0.73 ratio 5th gear set, but I assume you wouldn't want to part a (potentially) working trans out... Do you happen to know if the overdrive ratio is 0.63 or 0.73 in that trans? (also would have to have the 2.95 ratio first gear).
If there is a part number tag still on it ####-### that may be of some good reference.
Thanks!
Thanks!
Engine: 355, 408
Thanks!
Thanks!
Car: 1991 Z28
Transmission: 5 Sp
Did you sell the 145 mph cluster? If not I would be interested and how much shipped to 33572
Engine: 355, 408
Car: 84 camaro z28 H.O
Engine: 305 H.O
Transmission: world class T5
Axle/Gears: 3.73 limited slip
do you still have everythig for the t-5 swap?
Engine: 355, 408
Engine: 305 H.O
how much do you want for everything else? I would also like it shipped to 17061
Engine: 355, 408
Engine: 4++,350 & 305 CIs
Do you have the factory dual cat setup?
Engine: 355, 408
Engine: 355, 408
T5 swap is sold.
Engine: 355, 408
Engine: 355, 408
Bump. I will be sending the chassis to the crusher soon.
Car: 84 Z28
I'm looking for a set of exhaust manifolds off a TPI, if you still have them.
Engine: 355, 408
Damon
Sep 26, 2015 04:29 PM
