[FL] 2 350 engines
Car: 86 iroc z black/gold
Engine: LB9
Axle/Gears: 3.42 posi disk
2 350 engines
I have for sale 2 chevy 350 v8 engines.
the first is a 90s vortec TBI 5.7 350,1 piece rear main seal. popular block for hotrods, this engine has roller cam factory and also can take a mechanical fuel pump.
Block 14093638
heads 14102184
This one ran when pulled but had a knock, it has been disassembled and had spun a bearing. Will need the crank turned or replaced, and block will need a hone from sitting. Complete engine intake to oil pan. Asking $ 300 for the 638 motor.
the second is a 96-99 vortec 5.7 350, 1 pc rear main seal. Also factory roller cam, comes stock with a good windage tray and provisions for a mechanical fuel pump. These engines have a higher nickel content which makes for a stronger block. The heads are the popular 64cc vortec heads great for budget high horsepower applications.
Block 880
Heads 062
This engine ran great when pulled, didnt smoke or knock. I planned on a 383 stroker and having the heads ported but decided to go LSX this time around. This one is also disassembled but comes with everything intake to oil pan including accessories and starter. Im Asking $550 for this one, all it needs is assembled with new bearings and gaskets and such. Would make a great budget hotrod or street rod engine.
Also have a Holley 600cfm 4bbl carb, almost brand new in great shape. I bought it new for $399 and barely used it, asking $250.
638 complete engine $300
880 complete engine with accessories $550
May do some trading for LSX stuff or 68-72 nova parts.
Would take $750 for both engines together as a package.
Call or text 239-896-6725
Block 14093638
heads 14102184
Block 880
Heads 062
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
