SLP 1 5/8" SS headers
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
As the title says, with y-pipe cut for packaging, asking $125 plus shipping. Note, an air tube on the passenger side is broken and will have to be welded to keep from leaking. I can weld it if needed but it won't look pretty.
Small dent on passenger side.
Car: '88 Formula
Re: SLP 1 5/8" SS headers
I'm replying to everyone by PM... just keep in mind that this is a huge box even with the y-pipe cut in half.
Car: '88 Formula
Since there have been a few questions about the headers and y-pipe here is more info. Not sure why I didn't post this the in the first place...
The y-pipe is set up for a single cat but would have to be cut to fit since I had a straight pipe instead.
I don't have a part number for the headers since I didn't buy them new. The full story is that SLP had a fire in their factory and someone bought pallets of parts that were coated in soot and other garbage. I bought one of the sets from him and had them sand blasted, then had the y-pipe made of steel... I never had the SLP stainless y-pipe.
Speaking of the y-pipe, it wouldn't line up right with the collectors when I did a motor swap (Dart Iron Eagle heads). That's why there is a collar welded where the driver side goes in front of the oil pan. So the y-pipe may need some work to fit your combination. If you don't have a welder, you could grind off the collar and use a stainless band clamp to put the y-pipe back together... you'll need to do the same back further (where the y-pipe gets close to the pinch weld, in front of the cat) since I cut the y-pipe to fit it in a box.
Car: 87 irocz 305 5.0 5 speed G92 option
Engine: 305 tpi
Axle/Gears: 9 bolt 3.45 factory gears
Looks like a good deal for someone. Mine look just like these but ceramic coated and I have the SLP y pipe.
Car: '88 Formula
$71 going to 88101 by FedEx
FYI, for those of you who are curious... it's a 44 pound box that measures 40" x 20" x 12" and I'm shipping it from 07847. UPS costs more than FedEx, and I'm putting in a dollar value of $100.
Engine: 4++,350 & 305 CIs
Would you sell just the headers? Toss the y pipe if you want.
Car: '88 Formula
Sure, I'll sell just the headers. I'll even cut the flanges off the y-pip so it will be easier to make your own. What zip code?
Ok, if you still have these in a week I'll grab them
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
What is the y-pipe, 2.25 to a 2.5" ?
Doesn't look mandrel bent huh?
-- Joe
-- Joe
Car: '88 Formula
For those of you interested here are the box dimensions and weights, it will be shipped from 07847:
With y-pipe, 44 pound box that measures 40" x 20" x 12"
Without y-pipe, 20 pound box that measures 21" x 23" x 11"
Please use the UPS or FedEx websites to figure out shipping costs. I don't mean to sound like a dick but I've wasted more time repeatedly punching numbers into both websites just to have people back out due to the shipping cost.
Car: '88 Formula
The y-pipe is 2.25" at the collector to 3" at the cat-back.
Car: 1991 Trans am GTA
Hey man i'm in central jersey, about an hour from clifton and i'm pretty interested in these headers for my gta don't really need the Y pipe but maybe need the flanges. maybe we can meet up half way
Car: 91 Firebird Formula
Engine: 5.7
Please drop me a PM if the headers haven't been sold. What will it take to weld the leaky smog tube?
Engine: 5.7
Its just the A.I.R. tube where it goes into the header tube. Its probably more common on SS headers when they have 3 separate flanges instead of one flange to bolt it to the head.
Just a expansion contraction thing.
Engine: 5.7
Thanks for the info, always trying to learn what to expect with a third-gen.
Car: '88 Formula
I've used a MIG welder on stainless before, but like I said it won't be pretty.
They're still available.
redformula88
Oct 14, 2015 06:08 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
