[MI] (Mostly) Complete Speed Density TPI Setup
Old Mar 7, 2015 | 08:16 PM
rick90gta's Avatar
Car: 1990 GTA
Engine: 5.7L TPI SLP Runners Accel 24lb Inj
Transmission: 700R4 Upgraded Internals, Shift Kit
Axle/Gears: Borg Warner 9 Bolt, 3.27 Ratio
Selling a mostly complete TPI setup from a speed density camaro. exact year is unknown, i bought this from ebay and decided not to use it. the pictures show the following:
Upper plenum is painted "wrinkle black". i checked all bolt holes and sealing surfaces and its in good condition
runners are middle of the road condition. couple small/medium dents as will be shown
Lower intake arrived with broken thermostat housing bolts and a corroded water passage. i extracted the broken bolts, repaired the passage with epoxy, cleaned all gasket surfaces and ran it through the parts washer. its not perfect but it should seal up and work just fine. the thermostat housing has some pits and may need to be replaced
the fuel rails include some mismatched fuel injectors of unknown size/condition. i would recommend replacing with new. paint on the lines is a little flaky but other than that they are in good shape
the throttle body is in ok shape, needs a good cleaning. the iac/coolant housing has some crud in it and should either be removed and cleaned or replaced. i didn't do this because i don't have a gasket for it laying around. the throttle shaft turns smooth and easy and the blades appear straight.
i have what appears to be all the bolts, throttle cable bracket, vacuum fittings and various sensors (unsure if any/all of them work) i will include with the manifold. i did not try to assemble it so i don't know if its all there. also have a factory style distributor i will include if so desired.
the system is missing the distributor cover
price is $200 OBO +shipping
Attached Thumbnails (Mostly) Complete Speed Density TPI Setup-002.jpg   (Mostly) Complete Speed Density TPI Setup-003.jpg   (Mostly) Complete Speed Density TPI Setup-005.jpg   (Mostly) Complete Speed Density TPI Setup-009.jpg   (Mostly) Complete Speed Density TPI Setup-010.jpg
Old Mar 7, 2015 | 08:19 PM
rick90gta's Avatar
Car: 1990 GTA
Re: (Mostly) Complete Speed Density TPI Setup
More photos:
Attached Thumbnails (Mostly) Complete Speed Density TPI Setup-003.jpg   (Mostly) Complete Speed Density TPI Setup-004.jpg   (Mostly) Complete Speed Density TPI Setup-006.jpg   (Mostly) Complete Speed Density TPI Setup-010.jpg   (Mostly) Complete Speed Density TPI Setup-012.jpg
Old Mar 8, 2015 | 02:13 PM
rick90gta's Avatar
Car: 1990 GTA
Price drop $180 OBO
Old Mar 15, 2015 | 01:08 AM
rick90gta's Avatar
Car: 1990 GTA
bump. no reasonable offers refused. this thing is just hogging up space in my shop
Old Apr 12, 2015 | 11:52 AM
rick90gta's Avatar
Car: 1990 GTA
throttle body is sold. accepting offers on the remaining components
Old Apr 12, 2015 | 01:26 PM
1BADZ28SD's Avatar
Car: 1991 Camaro Z28
Engine: 5.7Liter HSR
price on fuel rail runners and plenum?
Old Apr 25, 2015 | 10:46 AM
rick90gta's Avatar
Car: 1990 GTA
rails, runner and plenum sold. base and thermostat housing still available if anyone is inerested
Steve78LT
Feb 24, 2016 12:15 AM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
squiggy2
Aug 9, 2015 09:30 PM
86Base
Aug 8, 2015 01:34 PM
