[AL] CUSTOM 90-92 SPEED DENSITY COMPUTER AND HARNESS SETUP
Car: 1987 trans am, 1988 Formula
Engine: 305 LG4, 305 LB9 TPI
Transmission: 700R4 in both
I have for sale a tpi custom built speed density wiring harness. What makes it a custom harness is when I had it made it was built to put in a car that is either a carb to tpi conversion or a hot rod with a brand new install. Its made to use a big cap electronic 4 pin HEI distributor and no emissions equipment. It also is made so you can run your own electric fan control and fuel pump relays or external fuel pump separate from the computer since its not tied into the computer. All connectors are labeled and comes with instructions and has its own fuse for protection to the harness. This has never been installed and is a brand new unit.
Price is $365 firm. I'll include free shipping and a pack of black wire loom to cover the wires. Please note this harness does not control the fans or fuel pump as noted above. Also this will be sold as a set. I will not sell the computer or harness separately since this is a custom setup. Photos can be seen by clicking the links below.
https://fbcdn-sphotos-h-a.akamaihd.n...4bc5975f2d8287
https://fbcdn-sphotos-b-a.akamaihd.n...a7bc85173379ec
https://fbcdn-sphotos-c-a.akamaihd.n...49cfb7e49be50a
https://scontent-ord.xx.fbcdn.net/hp...c4&oe=557A7D34
https://scontent-ord.xx.fbcdn.net/hp...9b&oe=558A6219
https://fbcdn-sphotos-a-a.akamaihd.n...b9076aa2aeb5c7
Re: CUSTOM 90-92 SPEED DENSITY COMPUTER AND HARNESS SETUP
BUMP FOR A PRICE DROP... $325-- STILL FREE SHIPPING. Still including a free pack of black loom.
