I have the lower end from my L69 for sale. Was running perfectly when I had it in my car, removed it in January to replace my floors and put in my LS. It will need new freeze plugs replaced because a few of them are replacements as well as the water jackets flushed out because crud has built up in them. It has the flywheel, front pulley and balancer, camshaft, and lifters in it. Flat top pistons with valve reliefs in them. I also have the starter if you want it to be included. Cam specs are 202/206, .403/.415, 114.5. may separate the cam and engine if desired. - $250
Edelbrock Victor aluminum water pump that was on the engine. Brand new, just used to get the engine running right while it sat in my car. Car never left the garage to put miles on it. $180
