[OK] Mild SBC 350 and Trans only 200miles
Car: 89' IROC Camaro
Engine: 350 HO
Transmission: TH350 Turbo
Axle/Gears: Moser / 3.73
Hey Guys,
I built a 86+ Chevy 350 4BM, it currently has 220 miles on it so its still not even broke in. I came across a 6.0LS for rediculous cheap and have now decided to swap over to LS.
Build list:
350ci bored 30 over
Sealed Power 12.7:1 pistons
comp cam 270H
comp cam 1.6 gold roller rockers
2.02/ 1.60 heads ported and polished
Weiand X-celerator polished and ported drag intake ( no other one like it, they all come rough this one is polished ).
650 mighty demon blow through carb ( good for nitrous or power adders)
10AN stainless steel carb line
Ceramic coated Hedman Headers
Billet Timing chain cover
Billet water neck
Timing Gear set ( no chain )
Hand made polished aluminum valve covers
12qt. custom widened pan with crank scrapper and baffles
Weiand proflow polished aluminum water pump
new chevy alternator
billet brackets
Cog pulley set
High flow oil pump
MSD Starter
MSD billet distributor
MSD .8 plug wires
NGK Lazer Iridium plugs
All aluminum and billet pieces have been coated with POR 15 clear coat so theres no polishing needed.*
I also have a TH350 TCI SuperStreetFighter trans that can be sold with or seperate
I would like 3500 obo for the SBC
And 1500 obo for the trans
Buy them together and ill cut you a deal. I will ship if needed, send me a message and i will get you a quote.
Build list:
350ci bored 30 over
comp cam 270H
Billet water neck
billet brackets
Cog pulley set
High flow oil pump
MSD Starter
MSD .8 plug wires
Engine: 350 HO
Re: Mild SBC 350 and Trans only 200miles
Thank You, theres no way i could build it again for what im selling it for, the carb alone was 700$.
Engine: 350 HO
I have video of it running if anyone is interested.
91TTOPZ
Oct 14, 2015 06:01 PM
509 camaro fan
Oct 11, 2015 01:52 AM
