[MD] '165 Memcal modified for burnable custom flash EEPROM chips and '165 TPI ECM
Old Mar 13, 2016 | 07:19 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
I have a '165 ECM memcal that I modified to accept flash writable EEPROM chips using a Moates chip carrier. This allows you to burn custom chips using Tunerpro and a flash burner such as the Moates burn1. This memcal that I modified w/ the chip carrier was a 1989 5.7 automatic Hypertech memcal, so it has the 5.7 v8 failsafe chipset on it as well. I can burn whatever .bin file you want onto this chip, provided that I can get the .bin. I will turn VATS off and set custom fan temps but that is the extent of .bin modifications that I will do. I still have the 1989 5.7 Hypertech Super Chip that came with this memcal and can also provide you with that chip instead of a custom tune, if you just want to run this as a 1989 5.7 automatic Hypertech Superchip. The Hypertech tune has more aggressive torque converter lock/unlock settings and lower fan temps, as well as other changes in the tune.
I also have one last '165 ECM. This was previously remanufactured and I have tested it on a running vehicle.
$145 shipped for just the memcal with the removable chip carrier (including one flash writable 29C256 chip, burned to the .bin of your choice)
$100 shipped for just the 165 ECM
$195 shipped for the 165 ECM plus the memcal
neilcase
Feb 25, 2016 07:40 PM
327_TPI_77_Maro
Feb 22, 2016 10:16 AM
jimbo
Apr 25, 2001 08:06 PM
85F-body
Jan 6, 2001 10:35 AM
Godti
Nov 7, 2000 05:48 PM
