Looking for V6 stuff
Subscribe
Mar 13, 2016 | 08:28 PM
Who here is parting or has parted a 2.8? Looking for smaller parts. Getting a replacement 3.1 and need 2.8 parts to be compatible with my engine harness. Getting engine harness separate from engine but still need this stuff...
1. Fuel rail, don't need injectors, WITH COLD START INJECTOR and possibly fuel injector harness (with both 4-pin connectors)
2. Cold start injector temp switch next to coolant temp sensor in intake manifold
3. CAMARO MAF sensor for dual-snorkel intake, part number ending in 7557 or equivalent but MUST be working
4. Ignition coil bracket assembly (no need for coil) with EGR solenoid, preferably working and the black 2-pin wire running between the coil and the distributor module possibly
5. EGR vacuum valve assembly, NOT 3-solenoid "digital" as is on 3.1. Do not need transfer tube but do need exhaust manifold riser
Might be more later but this is all I can think of at the moment... I'm going to try to get the cross-engine fuel lines and hoses and the throttle cable with the engine as well as the crossover exhaust pipe...
I will edit this later if the guy also has a 2.8 I can snag these parts from... I already know he doesn't have a harness which is why I'll be getting that separate.
Reply 0
Mar 13, 2016 | 11:23 PM
Re: Looking for V6 stuff
I've got most or all that stuff minus the maf. I'll double check the condition of everything tomorrow weather permitting
Reply 0
Mar 14, 2016 | 11:17 AM
I have a new water pump for a 2.8 never mounted just unpacked. I also have a ceramic coated intake and plenum in chrome. Make it look spiffy. Lol. I paid 150.00 alpine for the ceramic coat. Asking 75.00 for both not including shipping.
Reply 0
Subscribe
