383 AFR 190 head long block
Old May 15, 2016 | 12:14 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Im parting out the intake seperate.383 dynoed at 429hp and 489ftlbs. AFR 190 heads with arp rocker studs,arp head bolts,comp cams pushrods and SS comp cams rockers. New gm roller lifters and XFI268 cam. Cam is a billet core. Roller chain.Motor is brand new only dynoed. Scat crank/rods forged pistons. 9.1 compression pump gas friendly. 163 tooth sfi flexplate.4 bolt vortec truck block. Has factory 5 qt oil pan and complete oil system. Roller timing chain. $3500
File Type: jpg
Old May 17, 2016 | 12:15 AM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
Re: 383 AFR 190 head long block
Why are you selling and where are you located?
Old May 17, 2016 | 04:37 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
I have too many projects going on. I dont want to sell but I have no time to finish this one. Brand new motor for a lot less than new. Im located in MA.
Old May 18, 2016 | 08:37 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Bump
Old May 20, 2016 | 10:31 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Bump
Old May 22, 2016 | 02:41 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Bump
Old May 25, 2016 | 05:50 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Bump
89irocz355
Mar 28, 2018 08:24 PM
89irocz355
26
Sep 12, 2016 01:28 PM
antman89iroc
Alternative Port EFI Intakes
20
May 4, 2016 09:24 AM
89irocz355
Exterior Parts for Sale
18
Apr 11, 2016 10:17 PM
89irocz355
Mar 27, 2016 09:52 AM
