[FL] Holley Avenger 4bbl Throttle Body EFI Set-up
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
..... SOLD ... SOLD ..... Holley Avenger 4bbl Throttle Body Self Learning EFI ... Your choice between a 700 cfm TB w/65# injectors OR a 900 cfm w/75# injectors ... The 700cfm will support 200-400hp while the 900cfm will support 350-525hp ... Installation instructions included as are all necessary sensors , 4bbl Throttle Body , handheld programmer , Holley Avenger ECU , Main harness , power harness , and Holley external Fuel Pump ... $1200 shipped to the lower 48 .....
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
Re: Holley Avenger 4bbl Throttle Body EFI Set-up
Why are you not using this ?? What's need to run this on a 1970 camaro that's a 350 carb 5speed now....
Car: '87 Vette C4
..... I just added a choice between a 700 cfm Throttle Body OR a 900 cfm unit ... The 700 cfm has 65# injectors and will support 200-400hp and will work well with a 350 with mild mods ... the 900 cfm has 75# injectors and is intended for engines in the 350-525hp range .....
Car: '87 Vette C4
..... Price Reduced to $1200.00 shipped .....
Car: '87 Vette C4
Car: '87 Vette C4
..... Still Available ! .....
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
How tall is the throttle body?
I'm curious if these can be used with a carb hat in a blown application without the pods getting in the way. (I imagine you would use a spacer).
-- Joe
-- Joe
Car: '87 Vette C4
..... Its 2" from the bottom to the air filter mounting flange ... then up 3-3 1/2" to clear the injector pods and wiring ... 6 1/2" from bottom to the tip of the air filter stud .....
