[OH] 3400 Hybrid set up(For all 2.8/3.1/3.4L V6)
Old 08-17-2016, 11:10 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Cross threads but, this is a 3400 top end kit.
Gen 3 3400 heads with new seals, guides, and pocket ported as well. Comes with Stock behive springs, locks and retainers. Heads are straight and not warped. I have 2 complete extra hybrid set ups so im selling off this complete set up.
Gen 3 3400 upper and lower intake(slightly ported, gasket matched)
1k mile timing set will come as well with kit.
Set of 6 (21lbs/hr) Fuel injectors with wiring harness to hook up to 2.8/3.1/3.4L
I have a set of custom length pushrods to go with the kit. Depending on your cam these pushrods would be perfect for .030 preload. Originally from WOT-tech.com (listed for 165+ship and handling).
The lower intake does have 2 taps for temps sensors as this is required for a hybrid swap(one for the guage one for the ecm)
The thermostat housing, throttle body with all the sensors, fuel rail also come with this kit.
Im asking 350 Shipped to lower 48. 300 local pick up. I will also add a Delta cam if you would want which will match these pushrods. With the Cam 400 shipped or 350 local pick up. Thanks for looking.
Only 12 pushrods will be sold with the set I have 8 intake pushrods that are custom to the hybrid set up These measure INTAKE=5.939" and the EXHAUST=6.289"
Old 08-21-2016, 11:35 PM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
Re: 3400 Hybrid set up(For all 2.8/3.1/3.4L V6)
I should buy a v6 car just to play with this
Old 08-22-2016, 05:47 AM
fasteddi's Avatar
Car: 1991 Camaro RS
They are fun. I have so many v6 parts i could build 3 engines.. lol
