T56 crossmember, t5 621 bellhousing, header wrap.
Old 04-09-2017, 11:09 AM
Bald_eagle_machine's Avatar
Car: 2011 Camaro 2SSRS w/ Procharger
Engine: 6.2 LS3
Transmission: M6 TR6060
Axle/Gears: 3.45
Header wrap 2in x 50in $35 per roll, and $10 for the silicone spray. May be able to include some stainless steel zipties if you buy everything.
T56 hawks crossmember. $100
T5 big block t5 bellhousing. Was gonna use it for my t5 ls1 swap, but i bought a tremec t56 magnum instead. $120
Old 04-11-2017, 08:35 PM
Engine: 6.2 LS3
Axle/Gears: 3.45
Re: T56 crossmember, t5 621 bellhousing, header wrap.
T56 crossmember is sold.
Old 04-13-2017, 02:44 PM
dixie wrecked's Avatar
Car: 91 ws6
Engine: Carb'd 334 stroker
That bellhousing will work with a t5 and t56, as well as smallblocks, right? If so, I'm interested.
Old 04-13-2017, 03:11 PM
Engine: 6.2 LS3
Axle/Gears: 3.45
I know it bolts directly to the t5, allowing an 11in clutch vs stock. If the bolt pattern is the same for an lt1 t56 then it should work as well. But yes it will bolt to a small block. It's just used to run a larger clutch setup.
Old 04-13-2017, 03:14 PM
Car: 91 ws6
Pm sent
