$175.00 TPI GRANATELLI MOTORSPORTS Mass Air Meter
Car: 1987 Trans Am
Engine: 355 Edel Int, SLP, Edel heders 8PSI
Axle/Gears: 3.45 Borg Warner
Granatelli Mass air flow meter for TPI engines. This was on a 1987 Firebird. Didn't need since had custom computer tuning done. Made engine run great after big cam install! Also good for superchargers. Works perfect. I set it to stock L98 specs before i removed it (8 grams per second). I had to trim off the mounting screw holes to fit my supercharger setup.
Car: 1987 C4 Corvette
Engine: L98 350ci
Re: $175.00 TPI GRANATELLI MOTORSPORTS Mass Air Meter
what were the mounting screw holes used for.. I think this may work on my 1987 c4 corvette which has a L98 TPI. I will go check.. don't think mine uses mounting screws,, thanks, gary
Car: 1987 Trans Am
Hi there, I think they were for the Camaros that had the MAF mounted to the fan shroud. Not sure though. It will work on any TPI motor.
Car: 1987 Trans Am
bump
Car: 1987 Trans Am
SOLD
