posi 1987 4612825 Unit
Old Jul 21, 2017 | 07:56 PM
HellHound's Avatar
Car: I drive trans am. Duh
Engine: Yes, I have one in the trans am
Transmission: I have one of those too In trans am
Axle/Gears: In the rear of trans am
I have a posi unit that came with the car I purchased a year ago. I cleaned it up some time ago and it has been sitting Ever since. I don't know much other then that and it says
can 1987 and us4612825 on it.
25 bucks plus shipping. I don't need it.
Old Jul 21, 2017 | 07:58 PM
HellHound's Avatar
Re: posi 1987 4612825 Unit
Old Sep 22, 2018 | 06:47 PM
HellHound's Avatar
price change
Old Sep 22, 2018 | 08:12 PM
85irocZ2819's Avatar
Car: '87 z28
Engine: 383
Transmission: t56
Axle/Gears: 10 bolt 4:10
What are you looking for for your engines
Old Sep 22, 2018 | 09:51 PM
tedpants's Avatar
Car: '87 Iroc-Z
Engine: 5.7 350
Transmission: TH700r4
Can you carefully count the splines for the axles and teeth on the ring gear? Also, the diameter of the ring gear is important. I may want this as a backup. Thanks
Old Sep 23, 2018 | 02:30 PM
HellHound's Avatar
I like parts. Always have something going on.
Ill count them later when I get back
Old Sep 24, 2018 | 08:30 PM
HellHound's Avatar
It is 28 spline and 41 teeth
Old Nov 27, 2018 | 03:58 PM
HellHound's Avatar
Price drop
dont need it
Old Apr 18, 2019 | 06:55 PM
tater's Avatar
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
Do you know if this is a series 2 or series 3?
Old Apr 18, 2019 | 07:14 PM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
Just a suggestion here - auburn posi's are better when you have taken them apart to show how much if any are left on the cones and to make sure they're not cracked
if cones are worn out or cracked its a paperweight most people know to avoid used unless its internally inspected and shown in pics
on the down side they are a PITA to get springs and plates reinstalled if all is good, hope this helps
Old Apr 18, 2019 | 11:53 PM
HellHound's Avatar
I have no idea on what series it is. I don't know why it was in the car. The car had a posi in it. I just don't need it, and hate to through it away.
Im not taking it apart. I have too many things apart, to fight to put it back together.
Old Apr 18, 2019 | 11:59 PM
HellHound's Avatar
And you know, not to steer you away. But I don't know if it goes in a third gen or what. $25 bucks? It should have been sold by now. I'd take that for what it is. And I know nothing about rear ends.
