[OH] Thirdgen 10 bolt rear end
Old Sep 6, 2017 | 06:31 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
350 on local pick up with mini spool. 475 obo with mini spool and locker.
This is a solid rear end has Moser 28 spline axles, girdle with bearing supports, crush sleeve eliminator, Moser studs, currently a mini spool installed but have a lock rite locker with less then 1k miles on it that I will include for 125 more dollars. Worth almost 3 times that new. This rear is a freak. Best of a 1.56 60 foot behind a 385 all motor that runs mid 11s at the track. It has 3.23 gears in it as well. It was originally a 4th gen rear end at one time as it does have the rear abs sensors still on it. Only reason I'm selling is because I got a strange s60 as my car plans to be faster each year and although this rear end is worthy of abuse anything over 500hp is on the scary side. Pm or comment for more pics or info thanks. I'm located in nw Ohio southeast of Toledo by 10 miles
I also have disk brake backing plates I'll toss in. The drum brake components it has a new as well.
Old Sep 7, 2017 | 06:04 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Thirdgen 10 bolt rear end
Ttt price drop.
Old Sep 12, 2017 | 02:26 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Bump
Old Sep 26, 2017 | 08:45 PM
85TAsdro's Avatar
Shoot me a txt 4849444153. Im interested
Old Sep 27, 2017 | 04:51 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Sold it yesterday to a local. Sorry for the delay in a update.
please delete
Old Sep 27, 2017 | 05:26 AM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
please delete
if you go into advanced edit for the thread you can change from Ohio to select Sold in the location drop down menu.
