Parting out 1992 z28 tpi 5 speed car, 20,000 Original miles
Car: 89 iroc/90 iroc conv./06 ram
Axle/Gears: 3.27/3.27/3.91
Parting whole car. 5.0tpi 5 speed 3.42 disk posi rearend
Engine harness 250 shipped
Air cleaner snorkel 40 shipped
Air cleaner assembly 60 shipped
Much more
Much more
Transmission: Pro-built 700R4
Re: Parting out 1992 z28 tpi 5 speed car, 20,000 Original miles
I need the rear-most line that runs from the master cylinder to the prop valve. What do you want for that small brake line?
OK. PM me your paypal info,
Car: 87 GTA
Transmission: TH350
Axle/Gears: 3:42
Need the e-brake assembly. Cable from handle back. How much shipped to 76014? Thanks
What a shame. Only 20K and dead.
Car: 87 GTA
Transmission: TH350
Axle/Gears: 3:42
Yes cables and rear brackets. I am missing rhe right side from the equalizer back. I will include a pic. Thanks
Car: 87 GTA
Transmission: TH350
Axle/Gears: 3:42
The e-brake assembly is for my 86 IROC Z with a 10 bolt under it. Will it fit? Thanks
1 Post
Car: 1990 Camaro IROCZ
Axle/Gears: 3.45
looking for a few things, plastic pieces that go under the dash on both the driver and passenger side. I have a 90 t5 car i would think the are the same, as mine are missing. Also is the vehicle speed sensor from the t5 available? would be shipping to 48017.
Still won't work. The later calipers use a different cable. Really the entire E-brake system is different on later cars. The later E-brake lever is self adjusting, while the early system has to be manually adjusted under the car.
I need the dash piece under the steering wheel , how much shipped to 76502
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
How much for shifter ball shipped to 07728 NJ?
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
More pics of the tail lights? I have lights on my car that are OK, not great.
Looking for great ones. If they are in great shape I live in Milford and could come get them. Just let me know how they look, you are not exactly close so I don't want to make the trek if they have any chips or pieces missing etc...
Thanks!
Thanks!
Car: 1991 Z 28
Price for the A/C - smog bracket, just the bracket don't need the idler pulley or anything on it. shipped to South Dakota 57108. thanks
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
Does the car have an oil cooler in it?
#44
Car: 1969 Camaro SS
Engine: 355, roller, Profilers, FIRST tpi
Transmission: 200r4
How much for the passenger side serpentine belt bracket, the one that holds the AC?
Thanks.
Thanks.
