Strange 12 Bolt w/TQ Arm...$1,500
LS T56 $1,000...
W/bell $1,250obo
W/bell+Clutch&flywheel&hydro's $1,500
Final price drop on the axle.. Price is FIRM... Can ship at buyer's expense
Strange Engineering 12Bolt
-Better Torque Arm Backet Design
-3rd Gen Width
-Provision for Carrier Reluctor Wheel
-"Big Ford" Bearing Ends
-Welded Tubes
-LCA Relocation Brackets
-33 Spline Strange Axles
-Strange Spool
-Richmond "Race Series" 4.56 Gear Set
-2"x5/8" Wheel Studs
-1350 Chromoly Pinion Yoke
-HD U-Joint Strap Kit
-11" Optional Drum Brake's (like a $400 optiom...can be converted too Fbody discs)
-Tubular Torque Arm & Bracket...Stock Style Front Bushing
Axle has almost $2,000 in upgrades in addition to the original cost...also have a moly driveshaft and 3-way Comp shocks I may include for the right deal...
As for the axle with torque arm the price is $1,500 FIRM.
This set up was pulled from our 99Z28 T56 Drag Car... It went 6.90's in the 1/8th with 1.4x 60's and left @5,000+rpm... Car left hard enough to lift front end and totally mutilate a Edelbrock Tubular TQ Arm... Proven set up here...
LS F-Body T56... Trans worked before it was removed, it was having issue's coming out of 3rd gear.
No input shaft but it does have a front plate AND a Bellhousing...
Also have a NEW Spec sg-1 Clutch assembly, NEW LS1 GM flywheel, GM Slave & TB(**one of the lines is cut as seen in the pictures**), 4th gen pedal assembly and more...
T56 with Bell is $1,250...Without bell is $1,000Firm...
Will work with you on the deal and possibly add in extras especially if you are local.
Want it with the clutch & flywheel, hydo's, hardware and mote and its $1,500...
Clutch & flywheel $300
Pedal assembly $75
Hydraulics can be thrown in...
Also have a Neal performance universal aluminum clutch pedal assembly that can be mounted in different ways(On the floor w/pedal facing up/Under dash w/pedal hanging) and a Wilwood adj. master (built in reservoir) as well as a Tilton adj. Master(for use with remote reservoir) that both fit the Neal pedal assembly
Text's are preferred, please include your name and what your inquiring about and ill get back too you A.S.A.P.
Thanks,
Adam B.(716)428-1674
Will ship @ buyers expense (figure on $300 shipping for the trans or diff)
Also may be willing to deliver with in reason and meet half way..
P.S. Bucket of 50 chicken wings ON ME if you come pic it up... Come see Niagra Falls lol...
LS T56 $1,000...
W/bell $1,250obo
-3rd Gen Width
-Welded Tubes
-Strange Spool
Pedal assembly $75
Thanks,
Is the rear end still available?
Might be interested in shooting up from Toronto.
PM me if the rear end is still available.
