Small Block Rotating Assembly $300
Old Jan 21, 2018 | 11:10 AM
Screamin82 Z28's Avatar
Car: 82 Z28
Engine: 383 SBC
Axle/Gears: 3.50 9 inch
I have stock LT1 crank and rods from a 96 Trans Am, with .060 over-sized pistons for sale. The assembly has around 100k total miles on it (65k from the T/A and 30k from the current SBC build). This is a one piece rear main seal and will work in any SBC with a 1 piece. It is internally balanced and still in the block. I can disassemble and label for you so the balancing stays accurate, or you can take the current setup block and all. Block is junk (cracked cylinder wall).
For another $75 I will include the current cam, lifters, and timing gear/chain. This has about 15k miles on it. I also have a dyno sheet for this build if your interested. Comp XE268 hydraulic flat tappet.
Central, MA. Pick up only please.
Old Jan 25, 2018 | 11:24 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Small Block Rotating Assembly
You didn't list a price
Old Jan 25, 2018 | 11:42 AM
Car: 82 Z28
Engine: 383 SBC
Doh... $300
Casey_Butt
Apr 28, 2006 06:55 PM
Nocturnall
Jan 9, 2006 02:02 PM
